Copying track settings?
I am wondering if there is a way to copy track settings (plug ins, aux sends/levels, panning, volume) from one session to another existing session.
Specifically, I have a bunch of songs (as different sessions) that were recorded with the same drum set up. I dialed in the drum sounds while mixing the first song and would like to use the exact same settings on the other songs. Does anyone know a way to easily copy the settings from one session to another? |
Re: Copying track settings?
Johnny,
easy enough to copy plug-in settings...just save to "root folder" as opposed to "session folder" just remember to use the "save as..." option, and to name as something meaningful !! . Plug settings will then appear in the sub-menu for that particular plug in-just select, and the exact same settings appear. Not sure re the sends/pans/volumes etc - they're simple enough to re-create though. "the trouble with the French is that they have no word for "entrepreneur" G W Bush 2003
www.kitestudio.co.uk Mac Pro Snow Leopard 003 & Midas Venice desk Mindprint DTC Soundelux U99 Drawmer M-Clock |
I’ve done this many times:
I make a copy of the "master" session where I remove all audio regions. Then I import the empty tracks into the new session, and drag the audiofiles from the old to the new tracks. You might want to disable the plugins on the empty tracks session, to avoid cpu overload when importing. I hold, I think it is control, when dragging the regions to make them stick to their start time. The only problem is the track count limit. If you have more than 16, you will have to do it in more than one operation.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Copying "track settings" between projects in PT11 | yeloop | Pro Tools 11 | 7 | 07-29-2013 09:33 PM |
Copying FX settings | PELicanWord | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-04-2005 11:54 PM |
copying plugin and settings to different track | keithl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-15-2005 12:52 PM |
Copying Mix Settings | Bob Mould | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-30-2001 10:35 AM |
Copying settings in PT4.2.6 | Melodymaker | Pro Tools TDM Systems (Win) | 3 | 11-29-1999 06:55 AM |
