Old 09-26-2013, 01:47 PM
mccoyrare@yahoo.com mccoyrare@yahoo.com is offline
Default Recording at a rate of 5 Gb/s efficient enough
When using Protools 10 and using an external hard drive for the recording only and at a transfer rate of 5 Gb/s is that fast enough to not have latency issues?
Old 09-26-2013, 02:46 PM
mesaone mesaone is offline
Default Re: Recording at a rate of 5 Gb/s efficient enough
Yes. USB 3.0 is probably the third-best choice (behind Thunderbolt and eSATA) for an external recording drive... Although you will find that it is only 5 Gb/s on paper. There are more factors at play here - real-world USB transfers depend on the CPU, destination drive speed, and a few other things.
Technically USB 3.0 (which I assume you're talking about, since it's the only 5 Gb/s spec I know of) is faster than SATA II, which is what most internal hard drives use. That's not to say that all USB 3.0 external drives will be faster than internal drives, but it should be just fine for recording and playing back.
Old 09-26-2013, 03:00 PM
sw rec sw rec is offline
AVID says USB for Windows and Firewire for MAC.
Old 09-26-2013, 04:05 PM
I've used both USB 2.0 and Firewire 400 record drives on both systems, no issues. I've only used FW800 a couple times on Mac, so I can't say much about it. This was an external enclosure that had USB 2.0, FW400, FW800, and eSATA connections.
Old 09-26-2013, 05:45 PM
I would never use FW400 for a recording drive, especially if you're working with more than a small handful of tracks. I have both FW800 (Glyph) and Thunderbolt (LaCie) drives and can't say enough good about them. 50+ tracks - no problem; could probably go bigger but that's the biggest session so far.
Jack
QAPLA!
Old 09-26-2013, 05:57 PM
Maybe not. But it was my only option at the time, and it worked. It was only seven tracks.
Old 09-26-2013, 06:01 PM
That's why you got lucky and I said what I said.
Jack
QAPLA!
Old 09-27-2013, 11:49 AM
Wow thanks for the information, that helps me out a lot. What would be a good external hard drive to buy and use?
Old 09-27-2013, 12:22 PM
Mac or PC? FW for MAC, USB for PC. Something with a WD black..
Old 09-27-2013, 02:05 PM
If on a Mac - OWC drives and they're okayed by Avid for use with PT. Personally I use Glyph GPT50's on FW800 bus and LaCie's on Thunderbolt. All with 7200 rpm platters.
Jack
QAPLA!
Optimum Recording Bit Rate? brentrains General Discussion 11 11-12-2009 05:30 PM
At which sampling rate are you recording? SoundReplay Tips & Tricks 28 07-10-2009 12:17 PM
Best settings for efficient recording? cricket 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-25-2009 12:49 PM
Why sample rate is everyone recording with? Jak Pro Tools TDM Systems (Mac) 0 11-16-2003 04:20 AM
What sample rate are you recording at? EjA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 20 07-27-2002 12:59 AM
