Old 02-10-2011, 10:01 AM
aqueronte aqueronte is offline
Default Pro Tools Hardware Inserts 9 with ProjectMix
I have a Pro Tools 9 and a ProjectMix.
I have also external hardware connected via ADAT. The inputs and outputs are properly configured, both physically and in the I / O Setup. The device to signal that comes through ADAT 1-2 output, returns by ADAT 1-2 input.
If I make a hardware insert, creating an auxiliary track and inserting the hardware, I miss a rare thing:
The signal reaches my external device, it's process correctly, returns to the ProjectMix (in fact through the control panel ProjectMix I can hear fine) BUT IT DONT RETURN TO PROTOOLS.
That is, the auxiliary track where I have the insert return signal not processed.
If I add another track auxiliary with ADAD 1-2 as input I get good signal.
But then, I cant apply the Delay Compensation.
Any hints of what's happening?
thanks!
Old 02-21-2012, 08:10 AM
Chuckk1 Chuckk1 is offline
Default Re: Pro Tools Hardware Inserts 9 with ProjectMix
Looks like nobody here really knows all that much. I have the same unanswered dilemma trying to insert a hardware limiter across the 2mix buss/master. Nobody knows...or it can't be done. Pathetic.....
Old 04-12-2012, 08:28 PM
bisszerk bisszerk is offline
Here is a quick answer... You can use ouputs 1-4 and spdif out/ins for hardware inserts. Say you have your speakers on 1-2 analog out.. those are used up. You can patch the analog 3-4 out into the inputs of your FX box... then patch the outs from the FX box into the 3-4 analog inputs on the Projectmix. You are basically creating a loop.. Now... in Pro Tools on any track you can click "Insert" "I/O" and choose 3-4 for your Hardware FX instert! That should do it! -Brandon
Old 04-12-2012, 08:31 PM
BTW I don't have Pro Tools 9... so I can't attest to it working with delay compensation....I actually have to set my Projectmix buffers all the way down for it to work! -Brandon
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 09:19 AM
projectmix inserts plugins Cbeaulne Pro Tools M-Powered (Win) 0 07-31-2011 12:51 AM
Projectmix inserts? nickofeden Pro Tools M-Powered (Mac) 12 07-22-2011 02:29 AM
Projectmix hardware not detected BarryBianco Pro Tools M-Powered (Win) 1 08-31-2008 08:33 PM
Configuring Hardware Inserts in Pro Tools 6.1.1 htp_exe_producer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-12-2004 06:58 AM
