Old 09-21-2009, 02:54 AM
transistorschaltung transistorschaltung is offline
Default Fast Track Pro / M-powered 8 / no input signal
Hey everybody,
I hope somebody can give me some advice.
System is Win XP, SP3, Pentium 4 (3.2 GHz), IBM machine thinkcentre 8113.
I have installed the newest driver for the fast track pro and it is also "connected". The sample rate is set to 48kHz. Besides this I have an onboard sound card and a terratec 88MD pci card installed.
My M-powered 8 together with the fast track pro doesn´t work: I don´t get any input signal. Furthermore pro tools is not shutting down smoothly when exiting the program. As soon as I switch off the fast track pro interface then the program shuts down.
What´s strange: using my guitar rig 3 standalone interface the fast track pro is working fine (although I had to change the driver from "ASIO digdesign driver" to "M-AUDIO USB ASIO", which at least makes sense). It also works fine with my ASUS Laptop on Vista.
And the best: yesterday it worked and I swear I haven´t changed anything by myself.
I also checked the win default sound card and set it to the onboard card (as described in this forum somewhere), but that doesn´t make it run.
What´s the problem and how can I fix it? Thanks for help
Delayed Signal Fast Track USB Dirk Oosterwijk FireWire & USB Audio Interfaces (Win) 1 08-19-2013 06:08 AM
Signal oscillation Fast Track pro Captmoo Pro Tools 9 0 01-09-2013 02:20 PM
mbox,fast track input signal issue help? papitopinillo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-07-2011 05:53 PM
No record level signal : Fast Track Pro, Pro Tools M-Powered 8 mrmatter Pro Tools M-Powered (Win) 8 12-18-2009 10:32 PM
Fast Track Pro Outputting Mic input to Monitor, but Pro Tools 8 shows no mic signal changa86 Pro Tools M-Powered (Mac) 3 12-18-2009 10:06 PM
