midi / audio track issue
My first time working with MIDI.I created a drum track using EZDrummer by Toon Tracks. That seems to work well. Then I went and added an audio track for me to record a guitar part to the drum track.
When I arm the guitar track and the red light is activated. I hear the sound of my guitar through my monitors. when I then press play to start the drum track so I can play along, my guitar cant be heard any longer. Once I stop the midi track from playing the guitar track is fine again. Both the MIDI and guitar tracks are output through the main outs on my interface. Any thought to what this is happening? Thans in advance |
When you arm the guitar track are you trying to record or just jam with to come up with a part? If you're just trying to jam asking with playback hit option +k
Sent from my SGH-T769 using Tapatalk 2 |
Re: midi / audio track issue
I was looking to just jam and not record. I wanted to just flush out ideas and in order to hear my guitar through Pro Tools, I needed to arm the track. If I were to actually record, would that help?
Option + K worked perfectly....what does that do? What that short cut for?
Thanks again |
I looked in the Pro tools short cut reference PDF and don't see the
option + K It worked and allowed me to monitor my guitar through pro tools while the midi track was playing back. I don't know if this is a well know short cut to advanced PT users, but hopefully it helps someone. |
Track Regions Audio Playback Issue | leecappella | Windows | 5 | 01-04-2013 03:43 AM |
Audio Track Input Issue | WhiteRhino | macOS | 1 | 11-12-2012 03:51 PM |
Issue When running Midi and more than one Midi Track | amayhem | MIDI | 11 | 11-05-2009 06:52 PM |
MIDI Issue With M-Audio Fast Track Pro & Command|8 | kavieix | Pro Tools M-Powered (Win) | 0 | 03-28-2008 07:53 PM |
Little MIDI track volume issue... | hed | MIDI | 3 | 09-21-2005 02:12 PM |
