I have an eleven rack and mbox 3 w/PT 10.
I've been using them fine...alternating them depending on my recording needs. recently, my PT is unable to find hardware when the mbox 3 is plugged in. I deleted drivers and reinstalled, switch usb ports, used diff cables and nothing. it's always worked. my dev mngr identifies the mbox 3. you can even use the mbox to audio outside of PT. when I use the eleven rack, everything works perfect. I tried to change hardware to mbox when PT is up thru 11rack but it doesn't identify it. it doesn't work anymore. the only thing I've changed recently a few weeks ago is I updated to IE 10. but that was last month and PT was recently. holding N doesn't do anything either. help. |
uninstalled mbox drivers from device drivers screen, turned off computer. unplugged mbox, turned on computer, installed driver using avid drivers disc, plugged mbox in different usb, installed and now works.
solved. |
While I can't say for sure what solved you issue sometimes moving a device from one USB port to another in Windows will cause the Found New Hardware Wizard to come out and dance and sing. Once he's done his thing and reinitialized the device it and the driver are fine. One thing to check is that you have disabled any power saving features on your USB root hubs in Device Manager.
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? | Rongpat | Eleven Rack | 8 | 02-11-2014 07:42 AM |
Mbox pro 3 or Eleven rack | lincolngrillo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-04-2013 12:25 PM |
FYI - Fender Mustang IV works GREAT with Eleven Rack! | Justin1524 | Eleven Rack | 9 | 06-12-2011 06:53 PM |
Eleven Rack and MBox 3 | jimst57 | Eleven Rack | 9 | 12-28-2010 02:53 PM |
Mbox Pro Vs. Eleven Rack | panTera35 | Pro Tools 9 | 21 | 12-23-2010 12:48 PM |
