What Pro tools version will I need for Apples El Capitan Operating System.
I am purchasing a new IMAC with the El Capitan operating system. I currently have Pro Tools LE 8 on my old computer and using a Digi 002 rack as my interface. Will I need to up grade my Pro Tools software to work with the El Capitan operating system? Thanks!
Re: What Pro tools version will I need for Apples El Capitan Operating System.
If you have any option at all of getting an iMac with Yosemite, I'd strongly advise doing so. El Capitan changed a number of things in its graphic support that have had the unfortunate effect of making lots of GUIs very sluggish. You'll see other threads about this on the DUC. Pro Tools is by no means the only affected workstation. LogicX itself suffers from the same problem, meaning that Apple doesn't even appear to talk to itself.
Avid, as well as independent developers, are working hard to understand just what's going on. Until that happens, you'll have a much happier experience of PT12 on Yosemite than you will El Capitan. |
FYI- the supported OS versions are listed in the Pro Tools Operating System Compatibility Chart.
• linkedin •
No compatibilty between Eleven Rack and Mac Operating System "El capitan". | Diego375 | Eleven Rack | 8 | 10-26-2015 05:25 PM |
the operating system is not adequate for running avid pro tools | Bouhthehamster | Windows | 2 | 08-07-2015 01:09 PM |
Which Windows Operating System Is Best For Pro Tools? | TylerW | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-18-2010 01:01 PM |
Any Way to Use Pro Tools on Vista Operating System??? | chillax69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 08-22-2007 06:53 AM |
Which Operating System Version? | Edward Soady | Digidesign Hardware & Software | 2 | 02-24-1999 09:38 PM |
