Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 12-01-2021, 06:29 PM
Goombot Goombot is offline
Default DADMan software update 5.5.0 build2 Duplicate Outputs
With the new version of DADman whenever I make a duplicate output the second output is lower in level. For instance, I have a 7.1.4 AV source. Then I built a 5.1 AV source so I can route the side speakers to the back instead of the sides. So all it is is some different routing. Same trim levels. The source levels on the meters look the same from the 7.1.4 to the 5.1 but when I switch from the 7.1.4 to the 5.1 the output level drops at least 5 db. Anyone else experiencing this?
Old 12-01-2021, 07:46 PM
BScout BScout is offline
Default Re: DADMan software update 5.5.0 build2 Duplicate Outputs
No.
Screenshots of your sources/outputs (Mon) and screenshots of the routing matrix you've created will probably ferret out the configuration problem.
Pro Tools Ult 2021.12, HDX 3, MTRX/SPQ, HD OmniS1 x 2, FireHD x 2, Dock, iPad Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 12-01-2021, 09:47 PM
I figured it out. Some output trim I missed. Thanks for checking in about it.
MTRX/DADMAN output to multiple Spkr Outputs simultaneously with same stereo source? Jared_TL Pro Tools HDX & HD Native Systems (Mac) 18 12-06-2021 01:51 PM
DADMan software update Goombot Pro Tools HDX & HD Native Systems (Win) 2 10-28-2021 01:27 PM
DADMan outputs Goombot Pro Tools 2021 7 04-22-2021 09:27 PM
MTRX/DADman and Core Audio Outputs for Web or Logic...Stereo & 7.1.4 Funkster Pro Tools HDX & HD Native Systems (Mac) 4 03-16-2021 10:50 AM
Mojave breaks DADman software Johnny Hulst Pro Tools HDX & HD Native Systems (Mac) 41 07-31-2019 09:23 AM
