Old 03-08-2016, 11:52 PM
domdompompom domdompompom is offline
Default Trim plugin
When mixing, why you use the trim plug in if i can manually adjust the faders on each track?
Old 03-09-2016, 12:05 AM
Stig Eliassen's Avatar
Default Re: Trim plugin
Gain staging. You can also use clip gain. I get sent tracks that often are clipped, or virtually normalized. It is immensely annoying.
Many plugins these days respond/sound differently based on input level, too.
A softer level gives you headroom downstream for plugins and mixdown. It all adds up.
Old 03-09-2016, 12:08 AM
tekis tekis is offline
It's the plugin I use the most! Trim also has a polarity switch for checking phase.
[FONT="Lucida Console"]2023 Mac Studio, PT Ultimate 2021, S1x2, Dock, UA Apollo Duo [FONT]
_____________________________________________
Some credits:
http://www.allmusic.com/artist/john-...s/date-asc/100
http://soundbetter.com/profiles/3845-john-siket
Old 03-09-2016, 12:56 AM
I see the use of trim, however, why use it if i can lower my levels using individual faders in the mix window? Does the trim plug in lower the level of the master fader as well as each track you apply trim to?
Old 03-09-2016, 01:36 AM
I use Trim so I can get my fader to "live" around "0" (unity gain). Yes, you can use Trim on Master Faders too.
Some credits:
Old 03-09-2016, 02:09 AM
chrisdee's Avatar
chrisdee chrisdee is offline
I use trim on tracks befor plugins that doesn't have any output gain control.
But also on aux tracks befor effects like reverb and delay to control the input level.
Old 03-09-2016, 03:07 AM
Marsdy Marsdy is offline
You can use it on low gain track to raise the gain so the fader is in an area where it has much more resolution around 0dB. Therefore you can make more precise level changes with the fader.
Dave Marsden
UK
Old 03-09-2016, 02:22 PM
So where does the trim plugin come into play? When I start my mix or before I start applying plugins? As well, should I have my channel faders at unity gain and then apply trim, or can the channel faders all be at different levels and then apply trim to get them to unity gain?
Old 03-09-2016, 09:18 PM
deanrichard deanrichard is offline
As someone mentioned, gain staging. Some plugins, especially console emulations and others that try to emulate analog behavior, are very dependent on gain. For example, too hot of a signal will overload some console emulations.
Old 03-09-2016, 09:29 PM
I understand, however, my questions are if I trim should be the first plug in after I record an instrument and before I apply plugins. And if I should have my fader at unity gain. But, there is a general theme that my faders should be at -18, do I use trim to get my fader to -18? or play with the trim and track fader to get it to -18?
Trim plugin question musicman691 AAX Plug-ins 6 12-09-2018 04:48 PM
Yay we have trim plugin automation on non Hd boabyd23 Pro Tools 9 19 11-12-2010 10:11 AM
Is it better to use a Trim plugin or Gain plugin? SpinningDisk Tips & Tricks 5 01-19-2010 02:43 PM
Trim Plugin torquemada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-29-2006 03:42 PM
where is the Trim plugin? Dead River Studio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-05-2002 07:26 AM
