Re: Structure registered to my ilok but not authorizing
Sorry about the Delta thing Marc!
Well, I use(d) Structure in my home setup, not in the studio (to be clear about it...). So @home I have a Mac mini 1,66 Intel core duo, 2GB RAM, mBox Original. To reply on the "response" question; I think authorizing with challance-> response doesn't work anyway, because Structure can be authorized with iLok only. The challence/response system uses a key which is then installed on your harddrive. Or am I wrong? BTW Marc; are there improvements and changes in v2? I'm so curious... |
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
[QUOTE]
Hi Marc, I have two G5's in the studio. I'll check there (not now, but this weekend) if the iLok key will work there with v2. Still, Any succes stories with Intel machines would be much appreciated! |
Well.... So I installed Structure Beta 2 in the studio on Mac G5 1.8 DP, Osx 10.4.7, Protools HD2 v7.2, Mojo.
Same result! iLok authorisation still "expired" for Beta version 2 I suspect this is an iLok bug.... Maybe wrong date setting in authoristation? |
#16
Has anyone had any success at solving the authorization bug people are having with Stucture? I've been able to use the first demo but after installing the second demo, Pro Tools tells me that Beta 2 is expired. It is registered in my iLok account but Pro Tools tells me it can't find it on my iLok. I've synchronized over and over but it still shows up as being expired. I've read all these threads bu nobody seems to have been able to solve it. I've even thown away all the old Stucture files and reinsalled. I've even tried to re-download the key from digidesign to my iLok but it says "you already have an authorized version". Is this an iLok issue or Pro Tools issue? Hate to beat a dead horse but has anyone solved this?
Mini 1.8 w/ 2G RAM 10.4 PTLE 7.3 MBOX Thanks, - Mark |
#17
Just to be sure - have you downloaded the NEW auth for Structure Beta 2? There are different iLok auths required for each version - if you've only got the Beta 1 auth, it won't work for Beta 2.
Also, make sure that your computer date and time are set correctly - we've seen that cause problems with these auths as well. |
#18
#19
Yes I downloaded the Public Beta 2. My iLoks show Beta 1 and 2 but when I start Pro Tools it says Beta 2 has expired and can't find the authorization on my iLok. Either it isn't seeing my Authorization online when I boot Pro Tools or my iLok isn't getting the authorization from the website. The only thing I may have done backwards was install Structure before setting up the iLok license.
Thanks, - Mark |
Having trouble authorizing iLok and downloading license to my iLok | Ofentse Morris | Windows | 1 | 08-20-2012 03:36 PM |
iLok Broken; never registered | swalker2001 | Pro Tools 9 | 4 | 04-17-2012 12:25 PM |
Structure LE Not Authorizing on PT 9 CPTK2 (SL 10.6.6) | redline1.com | macOS | 0 | 01-14-2011 09:05 AM |
New iLok from Digital Village is already registered to another iLok.com account!? | Vytis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-06-2009 01:09 AM |
ilok not registered | abre | Pro Tools M-Powered (Win) | 1 | 12-06-2006 08:48 AM |
