Can we disable Avid Application Manager at startup?
Hi I'm using MAC and the avid app manager always start at login, I could not find a place to disable it's startup...
Thanks!
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt |
Re: Can we disable Avid App Manager at startup?
Wondering the same.....couldn't find either.
I use ccleaner for mac for keeping my mac free of crap.
Just as on the PC, you can manage your startup apps very easily with CCleaner by disabling them under the tools/startup menu. It is free for the basic version and works very well. Give it a try. OR you can change the RunAtLoad key to false in the com.avid.ApplicationManager.plist file in the Macintosh HD->Library->LaunchAgents You can use Text Editor but make sure that the extension is plist and not changed to txt or rtf.
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob Squaw Creek Road Studio Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1) | M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) | 3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 | Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X | Last edited by Cowboy Bob; 10-29-2015 at 06:58 AM. |
I haven't tried it so I am not sure if it's there but it should be.
Take a look here.
That solution worked for me. http://www.sibelius.com/cgi-bin/help...pid=3&&guest=1 |
Avid Application Manager | Jperkins | Pro Tools 12 | 2 | 06-29-2016 10:17 PM |
Kindly help me disable The Avid Application Manager | Pedro perez | macOS | 8 | 05-13-2016 08:52 AM |
Application Manager needs an option to disable launching when booting the system | zion | Pro Tools 12 | 124 | 03-31-2016 04:39 PM |
Avid application manager and Install shield at startup. | kol12 | Pro Tools 11 | 1 | 08-20-2015 11:14 AM |
Application Manager needs iNet permission on every startup | clausiii | Pro Tools 12 | 2 | 04-19-2015 01:57 PM |
