Old 06-03-2023, 12:50 AM
Robert01 Robert01 is offline
Default Pro Tools - Extend Selection Using Keyboard
I would like to extend or shrink a selection using the keyboard.
Desired behaviour would be something like: Holding SHIFT and pressing the '+' key would extend the end of the selection by the nudge value. Pressing '-' would reduce it. Holding OPTION + SHIFT while doing the same would change the beginning of the selection in the same way.
I have searched around but cannot find any way to do this. Any help is much appreciated.
Old 06-03-2023, 07:54 AM
Default Re: Pro Tools - Extend Selection Using Keyboard
Nudge left selection boundary right/left by Nudge value:
Option+Shift+Plus/Minus (+/–) keys (use numeric keypad)
Nudge right selection boundary right/left by Nudge value:
Command+Shift+Plus/Minus (+/–) keys (use numeric keypad)
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.6.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio / Monterey / HDX / MTRX / S6
Old 06-03-2023, 10:32 AM
Thank you for replying. I have tried this with no luck. It just moves the selection box the same as if I were not holding down COMMAND+SHIFT. It was one of the first ones I tried when experimenting.
I am using a wireless number pad but the keys behave as normal otherwise and if I go to Setup > Keyboard Shortcuts ... choose Search by Key and press the '+' key it shows 'Numpad Plus' and indeed even shows the 'Nudge Selection Later by Grid' option in the found shortcuts. An odd one.
Pro Tools 2023.3.0.
Old 06-03-2023, 11:18 AM
Works without issue here - 2023.3 / Ventura. Perhaps an issue with your wireless keypad or else something's corrupted in your shortcuts - I'd be most inclined to think it's an issue with the keypad; try it with a full-size wired keyboard.
Old 06-04-2023, 11:22 AM
Most likely. Thanks for confirming.
Old 06-05-2023, 07:50 AM
FWIW, it's been a while, but I've never been able to get external wireless num-pads to work correctly with all the modifier keys without using Karabiner:
https://karabiner-elements.pqrs.org
Old 06-06-2023, 12:34 AM
I've since bought an Apple wireless keyboard with number pad, all as one, and that works as expected. I've noticed when testing using 'Search By Key' that the modifier key isn't registering when you hold it down on the main keyboard but press 'minus' or 'plus' on the separate number pad. Clearly both need to be sent from the same keyboard. If a number pad had COMMAND and OPTION I'm sure it would work. A least for my problem.
Keyboard shortcut for 'Play Selection Start' Nichollodeon Pro Tools 1 08-27-2022 05:28 AM
Extend selection to grid command? Krolbol Pro Tools 9 7 03-19-2018 10:29 PM
Where do i extend my Pro Tools 10 trial? rockguitarist1255 Pro Tools 10 0 01-21-2012 10:43 PM
Extend a selection to a Marker SimonORorke Pro Tools M-Powered (Win) 9 06-25-2007 01:23 AM
keyboard selection..... AdamF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-29-2001 09:10 AM
