Old 01-26-2023, 12:43 PM
Default Re: Do I need more unified memory or more cores?
Originally Posted by BScout View Post
The 512GB are reportedly 2 x 256GB. This was reported in some tear down.
The 2x may or may not give max performance, say vs. systems that have 4x or more chips. I'd just want to see a good SSD benchmark and I expect they are out there if folks look around. Tim Apple just wants us to buy 8TB laptops.
Old 02-13-2023, 05:00 AM
Becharax's Avatar
Becharax Becharax is offline
Concerning the new M2 Max Macbook Pros .... Better to go for 1 TB or 2 TB ? in terms of Hard Drive Speed
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 02-13-2023, 05:17 AM
JFreak's Avatar
JFreak JFreak is offline
2TB
Janne
Old 02-13-2023, 05:39 AM
dominicperry dominicperry is offline
Early tests on the 1TB SSD on the M2 give a transfer rate of nearly 6000MB/s. Absolutely mentally fast.
So, buy the 2TB if you need the space, but I really don't think you'll need more speed. And I'm not sure there is much difference anyway - I can't find any references to 2TB being faster.
So, the very small drive sizes might be slower, but I'm not convinced there's much between the 1TB and the 2TB.
Evidence, not one word answers. That's what you need.
There's some information here about small vs 1TB, but nothing direct about 1TB vs 2TB.
https://www.tomsguide.com/news/macbo...-slower-speeds
https://www.macrumors.com/2023/01/24...ro-ssd-speeds/
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 02-13-2023, 07:12 AM
JFreak's Avatar
Agreed, 6GBps is insane. But then again, I remember saying the same words about 10MBps very long time ago.
Janne
  #16
Old 02-13-2023, 03:07 PM
noiseboyuk noiseboyuk is offline
Everything I’ve read says only the base models are affected by the speed drop, so I don’t think you’ll see any speed difference between 1TB or 2TB.
On RAM, I don’t think it’s quite as cut and dried as some of the replies here. I run a lot of heavy sessions (tons of VIs and a few sample libraries) entirely within Cubase and they rarely go above 20TB. If it’s a big orchestral thing I fire up the VE Pro template, but I run that disabled and only enable the instruments I’m using. That never hits 30TB, usually way below. (This method requires a lot of time to initially set up, but it has more than paid off over the years).
On top of that, the M series seem to be very efficient at using the blazing fast SSDs for virtual RAM. While you’ll run into trouble eventually, many users are reporting how well that works in practice. That RAM limit isn’t quite the brick wall it was, seemingly.
I know for my own work - tons of VIs and sample libraries, using a disabled VE Pro template - 32GB would be plenty. For a mobile rig that would be for simpler projects, I reckon even 16GB would go a long way. Of course if you can afford it the more the better, and you can’t increase it, but imo a lot of the advice in this thread is best practice from many years ago. With care and planning the need to max out RAM is not as pressing today as it was.
(T&Cs apply, YMMV etc)
EDIT - forgot one other important factor in the reduction of RAM use these days. With the blazing-fast SSDs, you can reduce the preload buffers of the sample players to something very low or zero, streaming everything straight from disk. In Kontakt or Opus you can use background loading, which just loads the notes and velocities you play on the fly. This has has HUGE impact on RAM use. Remember those libraries still need some RAM for scripts, GUIs etc, but your RAM goes a lot further these days.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
  #17
Old 02-13-2023, 04:41 PM
JFreak's Avatar
^^this.
I have been laughed at when I have presented this thoght about 16 gigs of Apple system-on-chip memory equalling 32 gigs of Intel conventional memory. So keep laughing, but smaller Apple memory is just as good as bigger Intel memory.
Janne
  #18
Old 02-13-2023, 05:50 PM
Carl Lie Carl Lie is offline
Originally Posted by JFreak View Post
^^this.
I think some just disagreed with you. I saw a video last week with a M1 to M2 comparison and also a 16 GB to 32 GB comparison. Although one had 32 GB the OS didn't use it during tests and swapped with the disk instead.
So you may be onto something.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
  #19
Old 02-13-2023, 06:18 PM
audiolex1 audiolex1 is offline
Dominic
I don't think there is 1TB and above. My M1 MBP 14" gets 5500 read and write with 1TB
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
  #20
Old 02-13-2023, 09:27 PM
BScout BScout is offline
My M2 Pro Mac Mini 4TB gets 7000 read/write.
Eucon 18.3 Unified Installer bobcats Avid S1, S3, Dock and Control App 3 09-13-2018 06:14 AM
What will help more? RAM? Flash Memory? or more Cores? johnnyv Pro Tools HDX & HD Native Systems (Mac) 5 12-16-2013 02:27 PM
When did mixer channelstrips color become unified? Armando Pro Tools 11 1 08-16-2013 10:32 PM
Why unified AAX plugin folder? ehausler Pro Tools 11 11 06-25-2013 12:40 AM
Optimum set-up for PT-cores, memory, etc Park Seward Pro Tools 9 0 11-07-2010 10:48 AM
