Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 01-17-2023, 02:34 AM
Marsdy Marsdy is offline
Default Carbon - Simultaneous Analog I/O?
Hi all
How many simultaneous analog inputs are available with Carbon? I see there are 8 XLR mic inputs and 8 line inputs on D-Sub on the back panel but are these available simultaneously giving a total of 16 analog ins? I’m guessing not but the Avid site isn’t very clear on this!
Dave Marsden
UK
Old 01-17-2023, 02:54 AM
dominicperry dominicperry is offline
Default Re: Carbon - Simultaneous Analog I/O?
Eight. Only 8.
There are only 8 A/D convertors per Carbon.
There are only 8 A/D convertors per Carbon Pre.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 01-17-2023, 02:59 AM
Originally Posted by dominicperry View Post
Eight. Only 8.
Dominic
Thanks Dominic!
Dave Marsden
UK
Old 01-18-2023, 09:36 AM
K Roche's Avatar
K Roche K Roche is offline
Originally Posted by Marsdy View Post
Hi all
Simultaneously NO.
To clarify a bit further, you can have 16 analog channels physically connected 8 XLR and 8 D-Sub at the same time But as Dominic said, there are only 8 converters ---so only any combination of 8 total will work simultaneously
And note the XLR inputs will override the D-Sub connections when there is a cable connected to the XLR's
Now I only have 8 analog connections--- So I use the first 4 XLR inputs for my mic's and I use the last 4 via D-Sub for my two stereo Hardware FX units
You may know this but if not --- be aware If you are using outboard Hardware units,, you likely do not want them to be going thru the Carbon Pre amps... So you need to go into the Hardware Set Up menu to make sure the appropriate "Line Bypass" are selected.
Note below I have line 1 & 2 bypassed because that is my AEA mic pre I use for my ribbon mics
Then 3 & 4 are on for my Condenser mics plugged directly into the Carbon
and 5-8 are bypassed for my hardware FX units
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 01-18-2023, 01:49 PM
Originally Posted by K Roche View Post
Simultaneously NO.
Thanks Kev that’s useful info. 👍
Dave Marsden
UK
Old 01-18-2023, 10:16 PM
trimix trimix is offline
Simultaneously NO.
I always use mic inputs 5-8 first due to their adjustable impedance, kinda funny that you've done exactly the opposite. With the new Pre unit, I'm kinda annoyed by the replication of that design decision, so you've got adjustable impedance on 5-8 and 13-16 only. #keepingitrandom.
(2) Avid Pro Tools Carbon
Avid Pro Tools 2023.12
MacOS Ventura 13.5.2
Apple MacBook Pro 16" M1 Pro 16GB 1TB 2021
Old 01-19-2023, 10:33 AM
K Roche's Avatar
Good catch -- Yes I don't remember if I tried using the different impedance option and did not hear much difference with my mic's,,,,, or if because when I used to use an A Designs MP2A as my mic pre that had impedance adj. I did not hear much difference and just hadn't thought about it ?
In any case I am glad you mentioned it... I may just do some more experimentation someday when I am bored
System :
Enjoy the Journey
.... Kev...
Old 01-21-2023, 04:46 PM
QuacksMeUp QuacksMeUp is offline
Default Re: Carbon - Simultaneous Analog I/O? (Gain Bypass)
If you are using outboard Hardware units,, you likely do not want them to be going thru the Carbon Pre amps... So you need to go into the Hardware Set Up menu to make sure the appropriate "Line In Gain" is bypassed.
Didn't know that one! Using a Shelford Channel into Carbon channel 1... and was confused why I had to select MIC as my input setting (instead of LINE). Gonna try the bypass and see what I get.
Would it matter if the input cable uses XLR or TRS? (i.e. Does Carbon assume Mic level because I'm using XLR? Would it assume Line level with a TRS input?)
Old 01-21-2023, 05:29 PM
From the manual:
“ Mic/Line Inputs XLR/TRS Combo Jacks 1–8
Both the XLR/TRS combo jacks and DB25 inputs can be used for simultaneous connection of mic and line cables to the same input channel. This allows mic and line inputs to be switched without cable re-patching. 1/4-inch connections to the combo jacks always use the Line input, while XLR connections always use the Mic input. If a 1/4-inch connection is made to a combo jack, that connection takes precedence over the DB25 connection for that channel input.”
Old 01-22-2023, 08:01 AM
Great info above. If you asked because you need more outputs, the lightpipe outs can handle that nicely(and cheaply if you work at 48K). The Behringer ADA8200 is not far from $200 and actually sounds quite good(plenty good for music). It can also give you 8 more preamps, but my favorite lightpipe preamp is the Midas XL-48(amazing on drums)
AES and analog simultaneous recording - lineup? Actionmusic Pro Tools TDM Systems (Mac) 3 07-01-2011 10:28 AM
Simultaneous ADAT and Analog outputs mixman4000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-12-2006 06:08 AM
Simultaneous Analog and AES/EBU out on a 96 I/O AVGuru1 Pro Tools TDM Systems (Mac) 4 01-10-2005 10:29 PM
16 Simultaneous Analog Audio Tracks? antnyzman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-25-2001 11:10 PM
16 simultaneous analog I/O on digi001 yayogaak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 09-08-2000 05:56 AM
