Old 10-24-2022, 07:17 PM
EVaschon EVaschon is offline
Default Is there a way to capture/export track volume??
Please forgive me if this sounds a little crazy or if the answer should be obvious, but I've just had an engineer tell me that the individual track volume levels for a song's rough mix, can be capture and exported through the "Commit" function or some other way. Is this true?
My gut feeling is although plugin sounds, FX and pitch correction can be captured onto a newly created audio track containing the desired output, track ("volume levels" cannot be captured by any means other than exporting an entire ProTools session.
Please help me with this if someone out there knows the definitive answer.
Thanks
Vaschon
Old 10-24-2022, 07:41 PM
smurfyou smurfyou is offline
Default Re: Is there a way to capture/export track volume??
Sure. Commit can optionally include volume.
~Will
Old 10-24-2022, 08:12 PM
Sardi Sardi is offline
Yep. As above, commit will render volume changes. You can also buss to another track and record in real-time. Lastly, you can solo what’s required and bounce to disc.
Old 10-25-2022, 06:02 PM
Thanks for your responses guys. This has helped a lot.
Export vs Bounce -- Volume Differences? quangaroo Tips & Tricks 9 07-19-2021 04:54 AM
Volume automation in omf export Chris Nuckols Post - Surround - Video 3 08-22-2012 07:42 AM
OMF Export from PT with Volume Automation Ginger Post - Surround - Video 1 03-25-2010 12:02 PM
AAF export to AVID w/volume graphs...? jackisdead Post - Surround - Video 6 09-03-2008 06:35 PM
Track fader volume to send volume smmdrum Tips & Tricks 9 08-12-2008 05:22 PM
