Selective enabling of ASIO channels in Pro Tools
Hey guys,
Is selective enabling of ASIO channels in Pro Tools 9 possible? I'm having a problem with an RME Digi 96/8PAD card always defaulting to ADAT output status when PT boots up, and it does not mult the outs to the AES/SPDIF outs, therefore I get no signal. I've not seen anything like this before, and removing the IO settings for the outputs doesn't do it. Wondering if anyone else has any thoughts before we have to make a new RME card purchase... Thanks for any advice! Sig |
Re: Selective enabling of ASIO channels in Pro Tools
So it's just inside or while PT boots? You should be able to save your I/O settings and that should automatically tell PT how to apply them....
However if your using AISO you are not running an interface....(As Far As I Understand it b/cI never have to select the AISO for the playback engine unless i am running an w/o an interface). if you need to run w/o an interface you could save a seperate I/O setting for the AISO config and another one when you run an interface..... If you are want to you could probably have some type of config in the Control Panel under sounds.....My MOBO let's me setup default ADAT and Mic and Line out and the Digital Outs......but this is windows......IDK if it will translate over inside of PT even if you are running the AISO engine. Hope that helps maybe i just created more confusion but it was a shot.
Ya, it has nothing to do with IO settings. When Pro Tools boots up it designates all the ASIO channels of the available hardware (in this case, the RME Digi 96/8PAD card). In Samplitude, I'm able to turn off those extra ADAT outputs which automatically tell the card that it can't output into 8 chn ADAT mode, and therefore must only use the S/PDIF and AES IO. I don't see anywhere else in Pro Tools that you can do that, nor anywhere in the system.
I think the only solution is new hardware, sadly. Too bad, it's for a basic system that needs to only be at 44.1k, and this card has worked really great for many years in this situation. It's only because I'm trying to bring Pro Tools into the mix that we're not able to use it. Thanks for your help, Sig |
Not enough ASIO output channels available.at least 2 channels are needed. | kudca | Getting Started | 1 | 05-26-2013 04:05 PM |
help with asio for all not enabling sound???? | wil2166643 | Windows | 15 | 05-10-2012 07:46 AM |
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. | scottthafoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 04-19-2010 01:45 PM |
Error: Channels 0/0 could not be set on ASIO driver | chili1222 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-03-2009 09:59 AM |
can i use my hd hardware as an asio 2 channels devide | polnetwork.com | Pro Tools TDM Systems (Mac) | 10 | 10-15-2002 09:55 AM |
