Old 04-14-2008, 03:34 PM
Paul PT Paul PT is offline
Default Which Midi Keyboard Controller?
Hey guys!
Just purchased an intel MacBook Pro with PT 7.4 with all the digidesign VIs - ie Strike, structure, velevet, hybrid and Xpand! etc and am looking for the best Controller Keyboard I can find that will run with PT and interface with these VIs.
I am interested in the new CME VX series and the M-Audio Axiom 61 - but am open to any suggestions...
Has anyone used these keyboards with the digi VIs or can anyone recommend a controller keyboard that would integrate into my system?
Cheers
Paul
Old 04-14-2008, 06:45 PM
cnswilliams cnswilliams is offline
Default Re: Which Midi Keyboard Controller?
I've seen promotional videos on a few of those plugins where they were using the Axiom. Don't know if that helps any, but I would think to promote a plugin, they would use the best controller for better sales results.
Old 04-15-2008, 12:07 PM
citi citi is offline
I use the M-Audio Axiom 49 and it works perfectly with PT, provided you install the JL cooper controller thingy. Preset 1 controls my transport and mixer (tracks 1-8) and preset 2 controls the plugs, (mixer 1-9 setting now correspond to the mixer style control plug - rotary work the rotary, but they don't always correspond to the most obvious control) You will still need to map them a little.
CiTi
http://www.checkonet2ent.com
Old 04-16-2008, 09:18 AM
docscholl docscholl is offline
Currently, I use the M-Audio KeyStation 61es, and (like you), I am limited on what I can/cannot do...but it does a nice job.
After watching several of the Digidesign video tutorials, I noted that Phil Jackson (in his "Pro Tools Accelerated Videos") uses an M-Audio Axiom.
Based on what I've seen and heard him do, as well as some serious research and questions to vendors, I decided to buy the Axiom 61.
It is currently back-ordered, and I assume that a lot of people like you and me have figured out it is a versatile keyboard.
Hopefully, it will be worth the wait.
003+ Factory & Mbox 3
Apple powered by OS X 10.5.8:
iMac 2GHz Intel Core 2 Duo/4GB SDRAM (8.0.5LE)
PreSonus DigiMAX FS
Old 04-16-2008, 10:55 AM
TCM's Avatar
TCM TCM is offline
Check out these tutorials how to set up an Axiom for PT!
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 04-16-2008, 12:12 PM
BPlayer BPlayer is offline
I have the Axiom-61 and have had no problems. I purchased the Axion and a computer from Sweetwater together and they set them both up before shipping them out. No complaints here so far.
Old 04-20-2008, 03:26 PM
The Dougfather The Dougfather is offline
If you have the cash then the axiom is great, semi weigthed keys and plenty of knobs to twist. On a lower budget i'd recommend the M-audio oxygen series, i have the 61 version and it works great with LE. It doesn't even need any usb drivers its 100% plug and play.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
USB MIDI Keyboard Controller CharlieX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-13-2007 05:55 AM
MIDI keyboard controller connolly MIDI 1 10-26-2007 11:46 AM
OT:Mac Keyboard into midi controller? Tim R. Pro Tools TDM Systems (Mac) 1 03-10-2005 06:22 PM
Using a midi keyboard controller grantarctica 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-15-2005 03:06 PM
Midi Keyboard Controller secutanudu MIDI 0 02-16-2003 03:46 PM
