Old 12-31-2006, 08:55 AM
Rob Ruce Rob Ruce is offline
Default How do I grab velocity flags by range?
solved
Old 12-31-2006, 09:19 AM
Stig Eliassen's Avatar
Default Re: How do I grab velocity flags by range?
Go to MIDI Operations -> Select/Split notes. Under "Pitch Criteria" you select All notes, and under "Other Criteria" you select the velocity range you want.
Old 12-31-2006, 09:51 AM
Old 12-31-2006, 11:44 AM
spkguitar's Avatar
Use the grabber tool and "lasso" the notes you want to change. It must be the notes. There is no way to select the velocities without selecting the notes.
Old 12-31-2006, 01:19 PM
spkguitar's Avatar
This would be a very useful feature.
I totally agree.
Old 12-31-2006, 01:48 PM
Rob, I know it's not graphic, but take a look at the MIDI Event List? Here you can edit the Velocity Values on the fly.
filosofem
Aaron Mulqueen - 001 HD Native
Old 12-31-2006, 02:28 PM
Also, after selecting the notes in a specific velocity range, you can easily trim the velocity while maintaining the relative values between notes. It's not like lassoing stalks, but still a simple and fast procedure.
Happy new year.
Old 12-31-2006, 07:28 PM
How can I grab the flag tops on the fly within the edit window by click + dragging horizontally withing a given velocity range without selecting all notes within that range
On PC, Rob, holding Ctrl+Shift and mousing chosen Velocity Stalks will respectively select chosen Velocity Stalks without selecting all stalks in between. Entering a value in the MIDI Note Attack Velocity display results in a desired change.
A implementation of such a feature in the MIDI Events List could turn some favorable advantages, yes.
filosofem
Old 01-01-2007, 04:16 AM
Steve@ZooWest Steve@ZooWest is offline
This is also a frustraion here. The best solution for me is to have the Change Velocity window open, and to have it set to Scale by: 100%, and then have the "Limit To" checked, with a minimum of 1 and a max at whatever is the greatest desirable velocity. This allows you to select all the notes in a particular section, but only edit the loudest ones. Not perfect, but often is a great time saver.
"Modern manufactured music is like art they sell at a furniture store."
http://www.weddingmusicproject.com/
http://www.weddingmusicproject.com/w...music-samples/
http://stevemillikan.com/
Old 01-01-2007, 12:38 PM
Yeah, Rob, that's correct, just click and drag selected stalks.
Try key command Shift this can be done in Note or Velocity view.
filosofem
START CLICK GRAB (PC) CTRL CLICK GRAB (Mac) Kris75 Tips & Tricks 2 07-23-2013 09:53 AM
Can't edit velocity only anymore? Notes copying with velocity data... kingtinker Pro Tools 10 5 11-12-2011 10:53 AM
red png flags eddie lamb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-18-2011 05:04 AM
Midi Velocity Range? dvjduck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-14-2011 10:28 AM
Limiting the velocity range of a midi performance tha]-[acksaw MIDI 6 03-04-2009 06:54 PM
