SPIDF CONVERTER?
can anyone please explain to me what a spdif to analog converter is and will it allow me to have 18 I/O's on my 002R instead of 16?...
Thanks volume9 |
Re: SPIDF CONVERTER?
I could be wrong, but I believe you can use EITHER the analog 1+2 inputs OR the SPDIF input, so I dont think you would get any advantage in getting a spdif converter.
You CAN get 2 EXTRA inputs (from 16 to 18) by doing the following: 1. Filling up all 8 analog inputs. 2. Using ADAT-format lightpipe with an ADAT optical-equipped A/D converter to get an additional 8 inputs. 3. Using an analog to SPDIF converter to get an extra 2 inputs. For a total of 18. There are a lot of analog to SPDIF converters out there, from inexpensive to pricey...do a Google search and many will pop up. An old DAT recorder with spdif output is a cheap solution, although it is only 16-bit. RP |
Get one of these and you'll be ready to go. You could of course team that unit up with one of these . That would give you at least 10 very nice additional inputs to add to the 8 analog already available. For a grand total of 18.
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
Thanks for the input guys
volume9 |
The boxes Macr0w pointed to will certainly work beautifully. But it is good to know there are boxes available that are a tad cheaper. But then you wont get that Apogee quality....
Presonus Digimax focusrite octopre (with adat-option)
What's that? - That's the machine that goes "pling". Bastiaan |
-Andrew |
SPIDF Problems | Rodge A | Pro Tools M-Powered (Mac) | 6 | 07-07-2007 03:59 PM |
SETTING UP YOUR SPIDF | wuskool | Tips & Tricks | 1 | 01-15-2007 07:38 PM |
TRITON SPIDF to 002, question... | powerjoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-21-2005 12:34 PM |
001 Spidf (0pt) NOT working!!? | studiouniverse26 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-08-2003 10:49 PM |
spidf on digi 001 | jkofoed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-12-2002 05:58 PM |
