Old 04-10-2023, 10:17 PM
milesofwire milesofwire is offline
Default PCIe HD Core not initializing hardware
So I’m pretty sure I know the answer to this already, but if a Core card basically locks up pro tools on startup, it’s toast, correct?
If I put a known working core in, everything works.
Digitest won’t even start with the bad core in the first slot.
But when I put it after the good core it shows up in Digitest and passes ironically.
But putting it back in the first slot, it’s a no go.
Old 04-11-2023, 03:53 PM
Default Re: PCIe HD Core not initializing hardware
Ok, the plot thickens!
So I have this one core card that won’t run in an expansion chassis.
And I have another the works fine in the chassis.
If I put the one that isn’t happy in the chassis in a Mac Pro it’s fine!
Definitely scratching my head on this one.
Old 04-11-2023, 04:01 PM
Be careful in all this that you don't have an intermittent bad board, PCB cracks, components physically damaged, etc. especially the capacitors towards the edge of the boards.
Old 04-12-2023, 02:27 PM
Power supply in the expansion chassis was the problem, everything is rock solid now!
HD 3 Core PCIe and 2 Accel Pcie cards JonGon Buy & Sell 0 04-05-2015 09:02 PM
PT HD8 - Stuck at Initializing Hardware (DSI) RoofTopLuki Pro Tools TDM Systems (Mac) 5 07-07-2014 11:03 PM
Initializing Hardware DSI steffen75 Pro Tools TDM Systems (Mac) 6 12-02-2011 11:03 AM
Problem Initializing Hardware (DSI) StanleyPat Pro Tools TDM Systems (Mac) 2 08-03-2009 08:32 AM
Initializing Hardware (DSI) ....Won't BOOT!! dversion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-11-2005 02:36 PM
