Slowed down playback without an interface
Hey all,
I have been using Pro Tools 2020.3.0 with my Macbook Pro, running Mojave (10.14.6) through an Apogee Duet 2. I am now away from home and when I opened my session with no interface, the audio plays back slower than it should. When I first opened the session and switched to Built In Output for the playback engine, I got a message saying this output's clock does not support a 48khz sample rate. Questions: 1. Will the audio play back normally when I plug in my Duet again? 2. Is there a way to use PT without an interface and NOT have the audio playback slower than it should, even though my session is at 48Khz? THANKS! |
Re: Slowed down playback without an interface
You likely have some other app or the OS locking the driver at some other clock rate. Fix that and the problem will be solved. the session is not affected.
Try using the PT aggregate device that combines the onboard input and output rather than just selecting the output as the device.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Tracks get slowed down randomly during playback | BetsyBrink | Pro Tools | Intro Discussion | 3 | 09-11-2020 02:38 PM |
Audio import playback is slowed | twistedinsane | macOS | 5 | 05-19-2019 07:45 AM |
slowed distorted playback??? | jyou10 | Pro Tools M-Powered (Win) | 5 | 07-16-2007 11:48 AM |
Audio seems to have slowed down? | proverb18 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-22-2005 09:37 PM |
slowed down playback with external harddrive??? | chronicmd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 10-25-2003 02:58 PM |
