What is \"DAE error-1122 was encountered.\"
My new Pro Tools HD system failed to open twice and each time gave me this error message. "DAE error-1122 was encountered." On the third try, the program opened fine. Can someone tell me what that means? Is this sort of thing a regular feature of PT (I've heard rumors), or was it just a one-time curve thrown to this newbie? Thanks,
Steve in Dallas |
Re: What is \"DAE error-1122 was encountered.\"
Below is what Digi recommends...... after you roam around for a while, you will notice that the "trash preferences..etc" comes up all the time. Do it. The improperly installed flex cable is also common on new setups. good luck, SB
You may have a bad Accel card. There have been some manufacturing tolerance problems resulting in a "timing reset issue" on newer Accel cards. Contact your dealer OR Digi Tech Support by phone to exchange out your cards if need be. (Point your dealer to the link below if you have any problems.)
The tell tale sign is if you *constantly* get -1122 Errors and have to attempt multiple start ups to boot even after using the Pro Tools Pref & Database Helper app. Read from Digi Tech Support here thread about "out of tolerance" pcie accel cards Hope this helps
It's only R'n'R but I like it. |
Not a one time curve. . . you may have some real trouble. See the link "blackmacdaddy" put in his post and you will see. . . Read the 2 posts above and do as they say. Try the steps first, but don't pull your hair out before you call Digi on this one. The only thing I would add is to try and run Digitest as well, but even if the cards pass that does not mean all is ok. Do you ever have a startup problem?
...for system configuration info see my profile (Click on member name) |
i had this error yesterday for the first time after installing 7.4. exactly the same procedure! never seen this before in nearly two years of working with 6.9 and 7.1 with the same core and accel card...
i haven´t touched the cards inside my G5 since the first install! |
Thank you BaileyBass, your suggestion and explanation of which prefs to trash got me up and running again......
never saw this DAE error before today. |
Re: What is "DAE error-1122 was encountered."
Had this problem with one of our G5s with HD3 PCI-X cards. For months, couldn't figure out what it was. A restart would usually temporary solve the issue. Finally got around to install fresh copy of OSX and PT8, but problem persisted. Long story short... it was bad RAM!
I have this from time to time like twice a month or so... restart always solves the problem for me...
Even now this still works... Thanks Bailey!
1122 error | Greene | Pro Tools TDM Systems (Mac) | 5 | 10-23-2006 09:05 AM |
1122 error ? | Greene | Pro Tools TDM Systems (Mac) | 6 | 06-23-2006 06:01 PM |
DAE error-1122 and DSI error occurred:-1122 | BOP2NITE | Pro Tools TDM Systems (Mac) | 6 | 04-19-2006 09:21 PM |
1122 error | Greene | Pro Tools TDM Systems (Mac) | 2 | 03-20-2006 08:44 AM |
DAE error-1122 was encountered | Durka | Pro Tools TDM Systems (Mac) | 2 | 02-02-2006 02:38 PM |
