Old 11-18-2000, 03:18 PM
tomhartman tomhartman is offline
Default Digi Control Panel Problem
I'm on a G4/350 with System 9.04
I've been using 5.01 of LE for months, but never installed the Digi Control Panel. I went back to the Digi CD Rom today to pull it off and put it in my System Folder and when I double clicked it just for kicks, it comes up with an error message that says "This control panel cannot be used on this computer." What gives?
iMac 27
Old 11-20-2000, 06:41 AM
DigiTechSupt's Avatar
Default Re: Digi Control Panel Problem
Assuming that you have perfomed the following, it should work:
-Installed the Digi CP in the System Folder>Control Panels folder.
-Removed the Digi Output Drivers from the System Folder>Extensions folder
-Restarted the computer
If things still aren't working:
-Trash the DigiSetup File, Pro Tools preference, and DAE prefs (the entire folder) from the System Folder>Preferences folder. Empty the Trash and restart the Mac.
-Open the Extensions Manager Control Panel. From the selected set pop-up menu, select “OS 9.x base” click on “Duplicate Set" at the bottom of the window and name the set. Scroll down and enable the Digi Control Panel, DigiSystem INIT, Digidesign DSP Manager, Digidesign Direct I/O, the Open Music System Extension and restart.
Brent
Avid Audio Tech Support
Support FAQ
Old 11-24-2000, 08:30 AM
BillJack BillJack is offline
what is the digi control panel?
after reading this message I looked on the
ptle cd and didn't see anything like digi control panel.
am i missing something?
Help w/ Digi Control Panel gaston13 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-29-2004 12:42 PM
Digi 002 command 8 control panel Oompah ProControl, Control|24, Command|8 2 05-18-2004 08:27 PM
do i need the digi sound control panel? roseberrye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-22-2002 04:32 PM
Digi Control Panel & iTunes EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-04-2002 03:47 PM
Sound Control Panel Problem fire2k2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-03-2002 06:54 AM
