Old 08-12-2012, 07:04 PM
mingalls mingalls is offline
Default Just setup pro tools 10 and have no sound coming through the ouput
Any help or cross checking points would be appreciated??
I'm running a Pre through a 16X16 Analog.
I get the input LEDs working but there's no output at all.
Ouputs for the track are set to ouput 1/2
Thanks.
Old 08-12-2012, 09:54 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Just setup pro tools 10 and have no sound coming through the ouput
Have you made appropriate selection in Pro Tools>Setup>Playback Engine?
Installed all appropriate drivers for your hardware?
Tried going into Pro Tools>Setup>I/O and clicking default input & Output?
Are you using just Headphones or Monitors as well? If monitors how are they are they powered?
What OS are you running and which version of Pro Tools?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 08-13-2012, 09:50 AM
phatbeatstudio phatbeatstudio is offline
Thanks.
Are you a brand new PT user or do you have experience.
All I mean is how basic is your PT knowledge. Sometimes people will assume you know what your doing when you don't and over look the most obvious stuff because they think you know it already.
From my experience almost every no sound issue is a I/O problem start there. Then go to BUSS,s
Do you power up your system correctly. read more about that in LE its a pain in the but.
Do you have TDM selected as your playback device in MAC or WINDOS prefs
In the PT prefs/hardware is TDM your playback engine. IT ABSOLUTELY HAS TO BE.
IS IT PLAYING THROUGH HEADPHONES .
Is the TDM card connected to the PRIMARY out of the interface.
Is the DIGI CABLE connected to the core card.
Do you have the proper out puts selected in hardware prefs +4 -10
Sorry for the newbie suggestions . Like Dime Bag Darrel said if its not working start with the cables. I don't think he meant Pro Tools though.
Are you even getting sound into PT. meaning no output to PT into a track or no out put to monitors. You say you get input LEDs working but no out put , Can you actually record on a track in PT. Is every tracks output set to 1/2.
is you master fader input set to output 1/2
If your a newbie rename 1/2 master . then set all your outputs to the master including master fader.
Do you have the input button or record button selected. It won't show a level unless one of those is selected.
No Sound Coming Out of Pro Tools u47u67u87 Getting Started 3 02-14-2014 03:10 AM
Pro Tools 9.0 no sound coming out of my monitors shamanrock Windows 2 08-05-2011 09:18 PM
no sound coming out of pro tools Sweepxcore Pro Tools M-Powered (Win) 12 03-19-2010 11:23 AM
sound coming out of wrong speaker in 5.1 setup :-( iMartin Pro Tools TDM Systems (Win) 4 01-15-2007 11:47 AM
Crackling ouput/no sound coming out of Mbox jayel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-10-2004 04:49 PM
