#31
Re: Pro Tools LE 7.1 Update
apparently the Digital Audition path has been fixed in 7.1 but it's a little late IMO because DV Toolkit users will lose DV Toolkit1 when they upgrade to 7.1
Unfortunate timing to replace the Audition path and force the DV toolkit 2 upgrade although the good news is that you won't lose the plugins, just the timecode functions and feet+frames. Digitranslator 2/Vocalign/DINR Le/ will all still work. |
#32
Got an MBOX2 and upgraded the software to 7.0 and 7.1. I do not immediately see an upgrade annuncement for the ignition pack (which I have not yet tried to use). Am I good to go with what I have? Mac OSX 10.4.5. |
#33
Pro Tools Editor, Producer, Mixer and Masterer since 1998 |
#34
I actually have another problem with the 7.1 upgrade. I got 7 with an MBox2 and it was working fine, but after I did the upgrade, now when I try to record and press the "rec enable" button there's really loud white noise and it won't let me record anything. I tried to find a feedback loop as the cause but can't figure it out. And what's better (or worse) is that it doesn't do it every time, it's intermitent. Has anybody had a similar problem?
I have a Mac mini g4 1.42 ghz, 512 memory, and use a Behringer mixer, the "mix out" go to the mbox2's line inputs. If nothing else, how hard is it to uninstall 7.1 and reinstall 7.0? Thanks |
#35
#36
The "Read Me" file on the 7.1 Update states that the Digidesign Database files will be rewritten in a new format once this update is installed and Pro Tools is run. If my disks are being shared with earlier Pro Tools LE 6.4 and Pro Tools TDM 6.4 systems, will the rewritten databases be compatible with the old versions, or will they have to be rewritten again?
I can't do the upgrade if there is an incompatibility between systems. I can't upgrade to Pro Tools 7 everywhere due to hardware compatibility problems. |
Pro tools 10 to 11 update.Pro tools crashing | AdamArnold | macOS | 7 | 06-27-2013 12:17 AM |
Pro Tools 6.4 Update, Update ;) | TheLP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 45 | 04-07-2004 11:17 AM |
Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac | Avid | Pro Tools TDM Systems (Mac) | 17 | 07-31-2002 06:24 PM |
Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac | Avid | Tips & Tricks | 7 | 07-27-2002 04:58 PM |
Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac | Avid | ICON & C|24 | 0 | 07-26-2002 03:14 PM |
