Old 11-23-2011, 03:21 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Default Crossfade "Adjust Bouds" as default option
I am just wondering why this option is still not selectable in preferences.
Often when editing dialogs I just need to have a basic crossfade between two regions (clips, sorry). If one of the region was processed with AS plugin like RX2 Spectral repair (which doesn't allow to have handles due un-proper operation) then I get this message: Skip invalid fade or Adjust Bounds.
Would be great to be able to control it automatically by checking / un-checking this option in preferences.
Also anyone noticed that in MacPro and PT HD10, all messages (with blue button) offering "OK" or "Adjust Bounds" or "Delete" e.t.c do not react to space bar. Only "Enter" affects them.
I jumped from PT HD 7.4 where space bar pressing was a time saver in this case.
Anyone knows if it's possible to make it work again?
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Can you have "center" as default view with multi mono plug in? dgoodi22 macOS 4 02-08-2013 12:41 PM
Getting "DAE can't get audio fast enough" msg after applying crossfade EricWillhelm macOS 4 09-06-2011 07:51 PM
What Version Was "Crossfade REX Files" Preference Introduced? ProTooler Pro Tools TDM Systems (Mac) 5 09-09-2009 05:52 AM
What would be the "Best" or "General" Quantize default settings? Norm Mix MIDI 0 07-10-2009 12:38 PM
"Bouncing" . . . . Can I CHANGE The "Default Setting"?? The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-17-2002 02:59 PM
