Hello,
Is it possible to get into the "edit" window on the 11Rack using a MIDI controller? I don't see a CC# in the manual that enables this. What I'm referring to, if I want to adjust the distortion or something, how do I get to that window via MIDI? I have the "knob #" CCs set up, and I have the distortion on/off setup. I know there's "distortion setting 1, etc." I can assign. But I want to be able to see the controls for whichever parameter I'm messing with so I can just use the "knob 1, 2, 3, etc." and not have to setup every corresponding setting to a MIDI controller. Would it happen to be a program change, NRPN or a MMC? Thanks for your input.
Mac Pro 8-core 3ghz, OS 10.6.7, 16GB ram PT 8, Digi002, Cubase 6, Logic 9, MOTU 2408mk3, Eleven Rack |
The MIDI info pages accessible through the ER's UI are more comprehensive than the manual. That said, I don't recall having seen any commands to control the UI via MIDI.
![]() Quote:
Basically, if I need to edit a parameter on one of the stompbox effects I have to access it on the 11Rack or through Pro Tools, correct? It'd be nice to have a MIDI command to access the "edit" page.
I don't think it is possible to navigate the front panel UI via GUI but it is possible to set the "value knob" values via midi, knob 1 CC# 101 though knob 6 CC# 107 which it sounds like you are doing already. AFAIK there is no equivalent to the scroll wheel, EDIT and SW1 etc. buttons that would let you change what all those value knobs are affecting.
Post midi navigation suggestion on IdeaScale, my gut feel is most people will be OK with how it is now but you never know, I'd be happy to be wrong. Darryl |
![]() Quote:
IIRC, the only thing you can't do via CC commands is to change models. |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 04:04 PM |
002 rack "clicks" and Windows beeps when "Setting Up Midi" or | sw0mgt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-03-2012 04:42 PM |
2 Problems after Upgrade PT9 to PT10: "Controller-Personality MBox3" and "MP3.dll" | Eviltubbie | Windows | 5 | 07-03-2012 11:39 AM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 01:28 PM |
"Linking" midi keyboard controller to NI | unclestanky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-13-2003 07:31 AM |
