Old 01-26-2011, 08:59 PM
Hamdi Hamdi is offline
Default Original Peavey PC-1600 midi controller with PTHD8/9
Is anyone @DUC using this midi controller as a fader controller for PTHD8/9.
Thanks.
Old 01-26-2011, 11:18 PM
sunburst79 sunburst79 is offline
Default Re: Original Peavey PC-1600 midi controller with PTHD8/9
Thanks.
I had a CM Labs MotorMix running in PTLE8 awhile back. I can't remember if I had to drag the legacy controller profile into the correct folder manually or not. You may need to download the legacy controller personality profiles and install manually in order to get them to work. I realize that the MotorMix is not a PC-1600 but figured I would let you know that as far as I know most - if not all of the legacy controllers like the MotorMix, Mackie, Pro Control are still working even if they are unsupported.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Peavey Controller problem on TDM alistair Pro Tools TDM Systems (Mac) 1 04-04-2007 06:02 PM
setting up peavey 1600, as well as mtpav (parallel version)... isit420again 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-04-2002 01:22 AM
Peavey MIDI controllers (PC1600 or PC1600x?) Beale 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-12-2001 08:24 PM
Peavey PC-1600 Help! derekdarling Digidesign Hardware & Software 1 03-10-2001 08:00 AM
Peavey PC1600X MIDI Control Surface elzippo Tips & Tricks 2 02-21-2000 04:36 AM
