Old 01-11-2011, 12:02 PM
wuzlow wuzlow is offline
Default For those who have the Mbox Pro (3rd gen)
I have one and was wondering if it's just my mbox or if you guys have the same problem....
The main volume knob on the right when you start to turn it clockwise from "0" (knob pegged to the left) does it gradually increase your volume from the get-go or does any sound start at a certain point after turning it roughly an eighth of a turn?
When I start to turn my volume up, the sound pops in at a certain point on the knob and when I decrease volume it pops out at the same spot. Just curious if anyone else has this problem of if its just my mbox.
Thanks!
Tom
Dell XPS 420 Desktop
Intel Core2 Quad Q6600 @ 2.40Ghz - 3 Gigs of RAM
Windows 7 Ultimate 64bit
Dell Vostro 3700 Laptop
Core i5 M 520 @ 2.40Ghz - 4 Gigs of RAM
Windows 7 Ultimate 32Bit
Pro Tools 9
003 Factory
Old 01-11-2011, 01:23 PM
hammerransom hammerransom is offline
Default Re: For those who have the Mbox Pro (3rd gen)
Thanks!
I have not encountered that with mine.
Old 01-12-2011, 11:48 AM
Kanosan Kanosan is offline
I just started having this same issue after two weeks of use. Anybody know what the deal is? Is this something that changes in preferences or a faulty volume pot?
Here's a link to a quick vid I posted on youtube of this.
http://www.youtube.com/watch?v=wRqOm56Hcwc
Thanks,
Mark
Old 01-12-2011, 03:11 PM
DJ Hellfire DJ Hellfire is offline
Thanks,
Mark
Sounds like a bug to me. Does it do it with computer audio and auxillary audio too, or just Pro Tools audio?
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 01-12-2011, 05:28 PM
Kanosan, Mine isn't that particular problem. There is no audio for the first 1/8th turn or so from my volume knob then the audio pops in and volume can increase from there. It does this from any sort of audio input I have. Doesn't matter if its from Pro Tools (firewire) or iTunes (RCA or 1/8" jack). Its been like that right out of the box, I think its the volume pot that's bad.
Tom
Pro Tools 9
003 Factory
Old 01-13-2011, 08:33 PM
DJ Hellfire: that's a good question. I only use it for pro tools audio but I will try that out to see if I can isolate it. When I shut everything down and restart the system it corrects itself, but then starts up later on after continued use... so its still hard to say if its hardware or a software glitch. I don't muck around with my preferences other than buffer sizes really, so I don't think it's anything on my end..
Wuzlow: Mine worked great for two weeks before this started up. Be sure to check into the Driver Control Panel to make sure things haven't been magically changed on you. Low latency monitoring stopped working for me yesterday too, and I had to change some things in the DCP even though I had yet to open it to set my preferences.
Old 09-18-2011, 05:41 PM
relaxo relaxo is offline
This is what my brand new MBox3 Pro is doing right out of the box! Anyone find a solution or a fix?
Old 10-28-2011, 10:22 AM
fieldbeyond fieldbeyond is offline
I'm having the same issue here, no volume at all until around 8 o'clock and then it kicks in and is adjustable from there onwards, but again no sound when turned back below 8 o'clock. Anyone find any info on this issue yet?
Old 10-28-2011, 11:06 AM
YYR123's Avatar
YYR123 YYR123 is offline
take it back and get a 003r
Daniel
Old 10-31-2011, 12:17 PM
flautista's Avatar
flautista flautista is offline
003 is next to die, allready indeed
Jascha Koneffke flutist
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
RAM 24Gb corsair 1600 (3 sticks)
9-9-9-24
MAC
MacBookPro i7 2,3 15"
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
Updated Mac Drivers for Mbox, Mbox Pro and Fast Track Ultra now available Avid Technical Alerts 0 10-30-2012 04:24 PM
Mbox mix knob always plays a drum track,Mbox 2 and Pro-tools LE 8: Haezel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-20-2011 02:58 AM
Digi Tech Suppport? Pfft!!! Mbox/Mbox academic Questions WestPhillySoulzition 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-17-2008 01:03 PM
Mbox 2 Pro vs Mbox latency - Mbox 2 Mini pro? marcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-28-2006 08:18 PM
Mbox - Routing the computers audio through the mbox ie. CD Rom, system sounds brownmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-30-2003 03:22 PM
