Old 02-12-2009, 05:28 PM
beyond beyond is offline
Default Sync Session Tempo With Audio Track
New to PT. I have an audio track and I'm wanting to find the tempo of the track to sync up with the session tempo. What's the best way to go about this? Thanks.
Old 02-12-2009, 09:51 PM
fascinatedbymusic fascinatedbymusic is offline
Default Re: Sync Session Tempo With Audio Track
What kind of audio track? Does it contain transients?
Old 02-13-2009, 05:25 PM
Instrumental tracks.
Thanks.
Old 02-17-2009, 04:46 PM
Thanks.
To extract the tempo map of a certain audio track and sync or align to grid, try my method:
Record a click track(via instrument track) by playing along with the tempo of the target audio(your instrumental track) in quarter note interval. Once you've recorded your midi track, listen to your recorded midi notes if it's in sync with your audio and if some of the notes are slightly out-of-time, correct it by sliding your note either forward of backward in-time until you've achieve a perfect feel of your midi click with your audio track. You must have a good rhythmic ear to inorder to spot the out-of-time clicks. After you've perfected your midi click track, render the midi click to audio(mono will be OK). With the rendered audio click track, select your audio click track and activate beat detective. Under Selection/Contains: select 1/4 Note and click on the Capture Selection. Once you've set the Analysis, Sensitivity and Resolution, click on the Analyze. After that, Click on the Generate and tempo will be mapped. Kindly refer to the graphic below. There you go. Hope this is helpful.
This method is specially helpful if you have an audio track that has a lot of tempo changes and does not contains any rhythmic instruments(e.g. drums, etc.)
Enjoy. Thanks..
Old 02-21-2009, 08:24 AM
Thanks. Your method worked!!!
ModDelayIII loses tempo sync after reopening session clausiii macOS 0 05-30-2012 01:31 AM
Sync Audio - Editor Used Camera Track Only -Waveform Sync? milosziv Post - Surround - Video 7 11-30-2011 05:26 AM
Rex and ACID WAV files don't sync to session tempo blkdog7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-07-2008 07:56 PM
Intrument Track does not sync with tempo gjohung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-04-2006 11:22 PM
I need to make up a 3 tempo click track for a session on Sat, Help! Jules Tips & Tricks 5 03-17-2000 03:45 PM
