Can't launch since update to 2021.6
What's up Ducs...
I've been unable to launch PT at all since updating to 2021.6. I *think* it has something to do with my perpetual-renewal, which I bought via avid.com back in April, not working correctly, but I can't find any solutions in my Avid account. I'm getting this message on launch: Quote:
In my Avid account, I see my Software Updates + Support plan with an expiration of May 04, 2022, and the correct system ID & ilok ID. Is there something I need to do to get iLok to see my renewed license? I have read everything I can find on avid.com and in the emails I received, and can find nothing... btw this is happening identically on two systems, my m1 macbook air (16gb) and my mojave hackintosh (i9-9900k) thanks for any help you can offer, i'm really at wit's end here. ~peter in athens
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest * Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1 * PT 23.6 + Ableton Suite 11.3 * Soundtoys + Valhalla + Fabfilter + Spitfire * RME Fireface UCX II ~ Arturia Keylab Essential 49 * various clarinets, trumpets, flutes, plucky stringy thingies |
Re: Can't launch since update to 2021.6
You might want to check to make sure you have the latest version of ILM (Ilok Manager) and also be sure to sync your Ilok with the software.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
^^^^^^^ (quicker than me to post!)
If you haven’t already: In your Avid Master Account>My Products (bottom of page, LHS) enter your Default iLok Account/Link your default iLok User ID “Linked iLok.com accounts allow you to easily deposit activation licenses after purchasing new Pro Tools products and AAX plugins” Also check Avid Master Account>My Products for ‘Products Not Yet Downloaded’ Download the latest iLok License Manager, check the “Available Licenses” tab. If your new license is there, drag it to your iLok then Synchronize iLok Or Deactivate your (deposited 5/5/20) perpetual license, then Activate (return it to your iLok) Synchronize iLok
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife! |
thanks for the suggestion. i'm on 5.3.3 GM which seems to be the latest version. Synchronizing my iLok 2 has no effect, unfortunately.
* my ilok account is correctly set in the avid master account * my ilok license manager is the latest version (5.3.3 gm) * no products not yet downloaded * deactivating / reactivating the license has no effect also: sending the license to the cloud and back to physical ilok has no effect, nor can i authorize via cloud while the license is in the cloud.
Longshot:
(just in case you have a Cloud Session still open) Sign in to your iLok account on the iLok License Manager From File, click on Close Your Cloud Session https://avid.secure.force.com/pkb/ar...oud&popup=true
thanks again... i've never had a cloud session open (only ever used physical iloks). but i tried your suggestion, no luck.
i've just tried filing a ticket somewhere i ended up from the avid site (domain is c.na170.visual.force.com), though it's quite byzantine, and i'm not even sure it's for pro tools. if i hear anything i'll update here. but i'm not very optimistic about getting a response... Quote:
Get a free ASC Code/Number from your Avid account: Login to your Avid Master Account Under “My Support Center” click on “Access the Support Center (Portal)” This takes you to: https://na49.salesforce.com/500/o Under “Select Case Record Type” click on the drop-down Menu and select “Audio” (if your problem is not “Video”) In the 1st box, add a short description of your problem In the 2nd box, select “Artist Suite – DAW” In the 3rd box, select “Pro Tools” or “Pro Tools Ultimate” - or whichever choice applies to you In the 4th box, select “Pro Tools | Software” In the 5th box, select your Pro Tools version Click on “Submit My Question” You’ll be provided with a Case Number “Post Reply” to your DUC Thread, include your Case Number to help Mods or Higher escalate your Case
Pro Tools 2021.6
Win 10 Home | 21H1 | 19043.1081 I just had the same issue, after transferring licenses from iLok to Cloud for the first time... After trying the above suggestions a couple of times, and then, finally re-booting computer and trying one more time, and now it finally launches. |
Thanks everyone! I filed a case, and it turned out to be an error on Avid's end, where they hadn't sent the new license to iLok. They linked everything up correctly, and now it's launching!
thanks everyone for your help. ~peter in athens
Editing Bug after 2021.3 Update | colinato | Post - Surround - Video | 36 | 08-12-2021 06:51 AM |
What happened to DSP plugins in 2021.6 update? | Dot | Pro Tools | 11 | 06-27-2021 07:14 AM |
Update hdx firmware from 2021.6 or need last version? | arche3 | Pro Tools HDX & HD Native Systems (Mac) | 2 | 06-25-2021 07:10 PM |
Update to 2021.3.1 now midi and software unstable | biggamen | Pro Tools | 9 | 06-03-2021 05:54 AM |
Pro Tools 2021.3.1 Update Won’t Install | MrOZ | Pro Tools | 4 | 04-22-2021 07:51 AM |
