Need help with allocating DSP
I would like someone to explain to me in a manor that makes sense how the DSP allocation works in 7.1 HD. I have been running all my sessions in 48voice 1DSP but have run into a few instances when mixing where I have run out of DSP. I have an HD2 Accell rig on a G5 with 4gigs of ram. At most I usually only have 24 tracks of audio and maybe 16 plugins going. I tried switching to 32 voice 2 DSP and it seemed to give me even less DSP to work with. This doesn't make sense to me, shouldn't 2 DSP be better than 1? Could someone explain this?
Re: Need help with allocating DSP
What way did you get less DSP to work with? what exactly did you have less of?? and what problems are you having? Running on 1 dsp 48 voices should be fine, unless you start to get error messages during playback! in which case try moving up to 2 DSP's. Chris
Allocating More Ram To PT on Intel Mac | EvilElfBoy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-21-2008 08:13 AM |
Allocating memory,PT Won't let me !! | rgriff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-23-2005 10:36 AM |
Allocating RAM | Engramic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-02-2002 08:18 PM |
allocating ram to Mac OS | Jepse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-16-2002 12:37 AM |
Allocating RAM | Chris SD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-29-2000 11:29 AM |
