If I activate a previously inactive Routing Folder, any VCAs that are in the Folder do not get reactivated properly. They appear like the attached screen shot, with the group name greyed out. I then have to go through each folder and re-assign the groups manually.
This happens consistently but only if the session is closed and then re-opened in-between de-activating and re-activating the Folder Track. This seems quite serious to me, especially if one is having to work fast and doesn't necessarily have time to check that everything is working that should be working ... I'm using PT Ultimate 2023.9.0 on an Intel Mac Pro. Last edited by marianna; 05-06-2025 at 10:45 AM. |
bump - this is a really annoying bug!
Bug and it's not just folders.
~Will |
![]() Quote:
It's a bug for sure. I run into this all the time; if the VCAs are inside a folder that is then de-activated and session closed, upon re-opening session and re-activating folder all VCAs assignments are inactive and have to be re-routed. Super-annoying, and dangerous if you don't notice it and print as is. 2024.3.1 here on MacStudios.
http://www.richbreen.com ---------------------------------------- Mac Studio / Sonoma, PT Ultimate 2024.10.1. HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Hello everyone!
Do you all have existing support cases on going? please feel free to reply with your case number so I can bump it up the team and get escalated if needed. Thanks!
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
![]() Quote:
https://duc.avid.com/showthread.php?t=425518
~Will |
I’ve created a case - number 04799871.
Thanks Tope. |
![]() Quote:
I added the image to your case and also a few more notes. One thing... what OS are you on ? Marianna
Marianna Montague Sr. Dir. CX and Community | Customer Advocate [email protected] cell +1 (813) 493-6800 AOL IM avidmarianna Twitter Avidmarianna We're Avid. Learn more at www.avid.com |
![]() Quote:
Can you create a case please or if you want I can do it - just let me know. Marianna
I'll create a case too.
IIRC this is a very old bug. I don't think it has anything to do with folders, just the action of making a VCA inactive. Upon re-activating it, it remembers the assignment but it is greyed out. Attaching an image of a session that has no folders and wasn't even closed and reopened. Just making the VCA inactive and active again.
~Will |
Another Folder Track bug: Solo cleared when folding track in Mix window | XJENSEN | Pro Tools 2020 | 12 | 01-18-2025 07:42 AM |
2021.10.0 No folder track Saturation? | garret | Pro Tools | 10 | 12-26-2024 02:23 PM |
Folder track solo issue | pherzfeld | Pro Tools | 5 | 11-07-2024 04:51 AM |
Routing folder track can be moved | lesbrunn | Pro Tools 2020 | 3 | 10-24-2022 08:50 AM |
Another Folder Track bug: Soloing a Routing Folder doesn't solo routing bus | XJENSEN | Pro Tools 2020 | 7 | 04-24-2020 07:29 AM |
