Control 24 faders not moving in vegas mode? please help
Hey fellas really need some help.. I bought a control 24 about a year ago and i just started construction on the studio and havent used it protools.. it seems the faders do not move in vegas mode anymore.. I always did the vegas test once a month to make sure everything was working and now everything lights up in vegas mode but the faders dont move.. Is there anything I can do.. thank u guys and god bless
adrian |
Re: Control 24 faders not moving in vegas mode? please help
any help is appreciated fellas please thanks
did you turn the motors off by ascendent?
any burnt smells? was it off or on between tests? if on try power cycling off then back on (you have probably tried this one already)
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
no burnt smells... wat do u think it can be
burn smell would make me think the PSU for the faders died, still could be w/o the smell
what about the other points
They are in banks of 8 and each bank has its own power supply cable from the power supply, so less likely to be power supply if everything else is working ok, as they usually go down as a bank of 8 only. But could still be power supply. They also have their own controller cable, and has its all 3 banks gone down I would hazard a guess it's something to do with the controller board. Again could be power to the board or component failure. Need to find an electronics engineer who can check it through. Chris
hi fellas thanks for the reply. what if i switch the fuse, would that work.. Im also in chicago i dont think they're service centers here
do u think it might be the fuse..
Is the fuse blown? as far as I know there is only the primary fuse nothing internal.
If the LEDs come on it's not the fuse You did not reply to my other questions?
hey craig thanks for the response. im not sure how to turn the motors off, how can i check that.
i tried turning off and on the power and all the lights move but faders dont.. thanks bud |
Any suggestion? control 24 meters dead in PT work in Vegas mode | crizdee | ProControl, Control|24, Command|8 | 1 | 03-28-2013 03:29 PM |
Control|24 randomly moving faders | ryankingsmith | ICON & C|24 | 4 | 11-23-2010 08:05 PM |
Vegas Mode...Motor Faders | gabrieljay | ICON & C|24 | 2 | 06-09-2009 08:38 PM |
Control 24 with no moving faders | olivine | ICON & C|24 | 2 | 09-11-2008 01:42 PM |
vegas mode stopped working on D-Control | tomcat | ICON & C|24 | 3 | 11-01-2007 11:15 PM |
