Old 04-20-2014, 12:16 AM
Mihael Hercog Mihael Hercog is offline
Default Digidesign I/O 96 gain problems
I have a problem with low gain levels on 1-2 output and 7-8 input of Digidesign 96. I checked +4 and -10 settings but nothing helps. Gains remains low.
Does anyone know if there is any reset procedure for Digidesign 96 or do I have to deal with damaged pair of inputs and outputs? I'm on Pro Tools 8 HD3 on Mac Pro.
Best,
Mihael
Old 04-20-2014, 10:36 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Digidesign I/O 96 gain problems
I'm sure I'm asking a dumb question, but what preams do you use? Digidesign HD interfaces only accept LINE-LEVEL signals...
Janne
Old 04-20-2014, 03:07 PM
Yeah, I know that they are line levels. I noticed when I output 1-2 out of Digidesign to Presonus Central Station and did a calibration on Presonus and levels didn't mach. Then I changed outputs to 3-4 and it was ok. There I knew that I have a problem with 1-2 output with low level.
Than I connected my outboard TC reverb to insert 7-8 what means input and output 1-8 and the signal back in was low. When I moved to 5-6 it was ok.
If anyone have a clue I would appreciate very much for help.
Best,
Mihael
Old 04-21-2014, 12:12 PM
the dude's Avatar
the dude the dude is offline
I service and modify them if you are interested in sending it on in
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 04-21-2014, 12:17 PM
Craig F Craig F is offline
with a tone generator, a multimeter, and some cables you can check you ins and outs before sending it out
Thank you,
Craig
Old 04-22-2014, 10:39 AM
Thank you The Dude but I live in Europe so the shipping would cost me more than it's actual value of Digidesign 96.
Yes, I tested with sine tone and the outputs are low. It's strange that they are both equaly quieter because I beleive that if they were blown than it would not work at all or at different levels.
Thanx for help anyway :)
Best,
Mihael
Digidesign PRE: clicks when change input gain Vadim Kupriyanov Pro Tools TDM Systems (Mac) 2 03-24-2008 05:48 AM
Anyone have problems with gain on the projectmix? JBroad572 Pro Tools M-Powered (Win) 2 04-26-2006 06:17 PM
Gain Problems digimog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-23-2004 06:24 AM
Gain Problems with888/24IO RJ Pro Tools TDM Systems (Mac) 2 11-16-2000 11:58 AM
problems w/normalizing & change gain pesedjet Digidesign Hardware & Software 1 10-23-1998 02:36 PM
