Old 12-17-2002, 08:28 PM
kCmCg kCmCg is offline
Default crossover plugin?
anyone make a crossover type plugin? by that i mean take something (like strings) and split the frequency bandwidth to either 2 differnt outputs..or panned differently on stereo tracks? If not, is there a rigged way to do it? thought about duplicating the track and applying very drastic low pass/high pass filters to each one...but thought there might be a simpler way...
Old 12-17-2002, 09:45 PM
Rock_Artist Rock_Artist is offline
Default Re: crossover plugin?
You can do something abit weird but you can duplicate the track and put x2 C1-sc (Waves).
Then create 2 side-chains to getout only what you need.
with 2 channels it's possible i cannot think on a single track solution [img]images/icons/smile.gif[/img] .
Just wanna do music,
RA.
Old 12-18-2002, 05:29 AM
clausiii's Avatar
clausiii clausiii is offline
The cheapest way is: make two sends in your string track. Create two Aux Inputs. Each Aux gets a send as Input. Insert in one Aux a DigiRack 1-EQ with a low cut and select the cutoff frequency. In the other Aux the same but with a high cut with the same cutoff frequency. Then move the pan.
Hope this was the right answer..
Good luck
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Sub Sat crossover in Post spigots Post - Surround - Video 3 01-12-2005 08:07 PM
crossover question Joz Tips & Tricks 1 03-01-2004 07:37 PM
Can anyone help me find a crossover freq module for my EV XEQ-2 active crossover? ragbor Pro Tools TDM Systems (Mac) 2 11-08-2002 07:45 AM
Platform Crossover knobby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-30-2002 02:02 AM
Active crossover using PT Donny Tips & Tricks 2 08-01-2001 11:46 AM
