S6 M10 16 Fader / 5 Knobs
I have a session that has an EQ/Comp/DeEsser on each track. I've configured the console to utilize my 2 attention knobs zones to populate the EQ and Comp. I've created a custom map for the DeEsser on the knobs of the process module. When I select EXP and INS, I can access that custom map on the process module. Each time I attention a new track, the attention knob zones follow that selection. However, the EXP INS of the process module does not. I have to go up to the process module and re-select the insert of the newly attention track. Jeff/Eddie - is there a way that the expanded custom knob map on the process module can follow the attention track like it does for the attention knob zones? Thanks |
This would have to be a feature request since there is no option parameter to dictate what function type gets populated into the Process Module encoders.
Jeff |
Hey Jeff - Yes, that would be great! Maybe something in the Settings > User like "Process Module Selection Follows Attentioned Track"
Q for Jeff. Master Module Channel Strip on S4 | garret | Avid S4/S6 | 11 | 06-15-2021 07:01 AM |
AVID S4 Attention Track Knobs Master Module | sashi | Avid Pro Mixing General Discussion | 2 | 03-15-2021 11:50 AM |
Process module standard function | Cologne | Avid S4/S6 | 1 | 02-28-2021 11:18 AM |
Idea - Channel Module with Artist/S1 Series | sjgam | Artist Series | 8 | 10-08-2019 11:34 AM |
Curious about custom SSL module work | serio | General Discussion | 0 | 06-19-2010 07:56 AM |
