Old 06-14-2022, 08:01 PM
bergj00 bergj00 is offline
Default Process Module Custom Map Follows Channel Attention
S6 M10 16 Fader / 5 Knobs
I have a session that has an EQ/Comp/DeEsser on each track. I've configured the console to utilize my 2 attention knobs zones to populate the EQ and Comp.
I've created a custom map for the DeEsser on the knobs of the process module. When I select EXP and INS, I can access that custom map on the process module.
Each time I attention a new track, the attention knob zones follow that selection. However, the EXP INS of the process module does not. I have to go up to the process module and re-select the insert of the newly attention track.
Jeff/Eddie - is there a way that the expanded custom knob map on the process module can follow the attention track like it does for the attention knob zones?
Thanks
Old 06-15-2022, 06:57 AM
creativecontrol's Avatar
Default Re: Process Module Custom Map Follows Channel Attention
This would have to be a feature request since there is no option parameter to dictate what function type gets populated into the Process Module encoders.
Jeff
Jeff Komar
Solutions Specialist, Pro Audio
S6 FAQ
Old 06-16-2022, 09:04 AM
Hey Jeff - Yes, that would be great! Maybe something in the Settings > User like "Process Module Selection Follows Attentioned Track"
Q for Jeff. Master Module Channel Strip on S4 garret Avid S4/S6 11 06-15-2021 07:01 AM
AVID S4 Attention Track Knobs Master Module sashi Avid Pro Mixing General Discussion 2 03-15-2021 11:50 AM
Process module standard function Cologne Avid S4/S6 1 02-28-2021 11:18 AM
Idea - Channel Module with Artist/S1 Series sjgam Artist Series 8 10-08-2019 11:34 AM
Curious about custom SSL module work serio General Discussion 0 06-19-2010 07:56 AM
