Old 06-27-2009, 09:04 PM
BookSix BookSix is offline
Default Bounce to quicktime: audio gradually misaligns
Just started my first film score in Pro Tools HD today. Worked on one scene, about 5 minutes and did a bounce to quicktime. Upon viewing in quicktime (through core audio) I noticed the audio was inline at the top of the piece but by the end was off by around 1 second. And this is based upon my score plus the dialog that came with the video. Here are the specs:
DV Stream NTSC, 48k session, PT 7.3.1, OS 10.4.11, Digi 192. I also was running video out firewire (manually offset video to adjust) but even if this was the problem, the issue would be consistent, not continually worsening with time. Thoughts?
Brett Michael Wiesman
www.trackstarstudios.com
Old 06-27-2009, 10:16 PM
peppertree peppertree is offline
Default Re: Bounce to quicktime: audio gradually misaligns
maybe this video will help?
http://www.macprovideo.com/player/pl...7a2.mov&snum=2
`My name is Pro Tools HD, King of Kings:
Look on my works, ye mighty, and despair!'
Nothing beside remains. Round the decay
Of that colossal wreck, boundless and bare,
The lone and native DAWs stretch far away.
Old 06-28-2009, 02:01 PM
Thanks, i'll double check the session. But, if the frame rate was off in PT, wouldn't the preview playback in PT be out of sync as well? Right now, everything syncs perfectly within PT but the issue pops up when the video is exported.
Old 06-28-2009, 02:22 PM
minister's Avatar
minister minister is offline
I am able to BTQT in 7.3.1cs7 in OS 10.4.11 on a Mac Pro HD|2 no problem.
Things to look out for:
  1. Frame rate of session, QT, and Created QT are the same
  2. Do not SRC, this can cause drift
  3. I have not had success past QT 7.2 and thus I stay there
  4. No pull down or pull up is engaged unless you need it to be in which case, I don't think BTQT will work right.
  5. I have had best success not converting to other codecs either -- I do that later in QT Pro.
  6. Switch to TC, go into grid mode and make a selection Frame to Frame that is within the boundaries of the QT, anything beyond causes problems.
I suspect your problem is 2 or 6.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 06-28-2009, 04:12 PM
I was working with a 32khz dv file. Pulled that into my 48k PT session; could that be a problem? Or are you just talking about avoiding SRC when coming back out of PT at bounce time?
Also, i was using markers to set my start and stop boundaries. then end marker was for sure past the end of the video file. I'll have to go try bouncing just the length of the video... thanks
Old 06-28-2009, 04:39 PM
minister's Avatar
The latter. I think that is when it "scales" the audio to fit the QT, esp. since you went beyond the boundaries.
Let us know if you get it to work or not.
Tom Hambleton CAS
IMDb
-Starcrash
Old 06-28-2009, 04:42 PM
Will do, thanks!
Old 06-29-2009, 11:18 AM
Awesome, bounced within the QT region, kept the sample rate and use no pull up/down and it's all good. It makes sense now that I think about it. I noticed, when playing past the QT region in PT remains displayed. But, it only bounce the length of the region so afterward it must have stretched the video out to match the audio length... Anyway, thanks for the help
Old 06-29-2009, 12:49 PM
minister's Avatar
Glad you found the solution and it was that easy.
Tom Hambleton CAS
IMDb
-Starcrash
Bounce to Quicktime movies have no playback audio on 003 neilshah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-25-2008 03:26 PM
Bounce to Quicktime with 5.1 audio? potatohead Post - Surround - Video 2 10-31-2007 10:51 AM
Quicktime bounce plays audio, but no video! crizdee Pro Tools TDM Systems (Mac) 2 04-20-2007 04:34 AM
Bounce To Quicktime Only Outputs Audio Willard Pro Tools TDM Systems (Mac) 17 08-29-2005 06:27 PM
Bounce to Quicktime Movie Creates Only AUDIO ?! DMK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-11-2005 02:56 AM
