  #41
Old 10-01-2004, 01:38 AM
Simon666 Simon666 is offline
Default Re: PLOGUE BIDULE : free VSTs / AUs into Protools
Just a note that I've added a link at the base of the first post in this thread.
It's a page showing freeware Audio Unit instruments/fx that you can send into Protools using Plogue Bidule.
  #42
Old 10-01-2004, 11:26 PM
sleepingtiger sleepingtiger is offline
Simon,
Thanks for the AU link! You're the best! People like you make life nice. Much appreciated...
+=G=+
Pro Tools Ultimate 2024.10.1
Dell 7820 - dual Xeon 6132
64 gigs of RAM
Windows 11 Pro for workstations
HD Native PCIe
Lynx Aurora with LT-HD
Apogee
Mytek
  #43
Old 11-24-2004, 06:52 AM
Just noting that Plogue Bidule version 0.7 is now out at http://www.plogue.com/index.php?opti...electcat&cat=1 - if you've installed Plogue before you'll find that your beta has run out. I'll touch up my pdf manual in a few weeks, but this seems to run pretty much the same. This version will expire on February 24th 2005
  #44
Old 11-24-2004, 10:16 AM
OliJ OliJ is offline
Hey Simon, this is a bit OT, I know, but how's Coffa's DA/Masterplan going?
HD1 2.26 8 core Nehalem PT9.05 OSX10.6.8
  #45
Old 11-24-2004, 06:07 PM
Wow that is O.T
Ummm , initial application withdrawn after resident protests and new council . new plan being negotiated , don't know more sorry!
Wondering who you are ?
simon
  #46
Old 11-24-2004, 08:48 PM
simon
Greetings Simon
I Live just around the corner in Church street ..... small world....
Oliver
  #47
Old 11-30-2004, 11:23 PM
Version 0.7.001 available : Couple of bug fixes . I've also posted the 0.7 updates which I didn't do before ...
0.7001
Changes:
MIDI Buffer : added speed parameter.
Palette : shown/not shown state is now remembered.
Step Sequencer: only clicking is needed to delete notes (instead of clicking+move).
Bug Fixes:
Cable detection not working correctly with short curved lines that are straight.
Constant/Counter/Clip: can't set parameter when using it as a group parameter.
Main Window: shrinks to a tiny window when loading some files.
Main Window: using the key shortcut for processing doesn't change the button.
Preferences: changing AU/VST sorting by company names takes a long time.
Tools: some tool windows not remembering their size and position.
0.7
New features :
- You*can*now*register*Bidule*to*avoid*expiration*da te*(*and*feed*us*:)
- New*default*look
- Skin*support
- More*intuitive*MIDI*Learn*mode*for*all*bidules/plugins
- Feedback support*(send*values*back*to*controller)
- Support*for*7-bits*Relatives*and*14-bits*Absolute*MIDI*CC
- Processing*mode*now*in*the*window*for*each*bidule/plugin
- Sync*To*option*now*in*the*window*for*each*bidule/plugin
- Bidule*is*now*an*OSC*server*(all*parameters*are*ac cessible)
-AudioUnits*now*lists*all*the*installed*presets*for *a*plugin*
- AudioUnits/VSTs*now*have*an*extra*output*reporting*their*late ncy*(if*any)* **(so*you*can*do*your*own*latency*compensation*whe n*you*need*it)
- Internationalization*so*you*have*Bidule*in*your*na tive*language*(french*is*done)
- Cables*can*now*be*straight*lines*or*curves
- Scan*Groups*and*Scan*Plugins*are*now*separate
- Palette:*You*can*double*click*on*a*entry*to*use*it
- Palette:*new*"Find*Next"*and*"Use*Next"*search/use*utils
New*Modules :
- MIDI*Buffer
- MIDI*Synced*Buffer
- MIDI*Delay
- MIDI*Synced*Delay
- MIDI*Dummy
- MIDI*Multi*Channel*Remapper
- MIDI*Multi*CC*Remapper
- MIDI*Multi*Note*Remapper
  #48
Old 02-09-2006, 04:19 PM
mindnoise mindnoise is offline
HI,
just wanted to let you know the not only the new version of Bidule 0.91 is it´s also in
UNIVERSAL BINARY already.
best
greetz to Simon!
last: PT11.3.1
  #49
Old 02-11-2006, 11:51 PM
thanks for that Mindnoise. Haven't been keeping up with this and other threads (too busy!) so good to see you paying attention to it all !
  #50
Old 02-12-2006, 05:21 AM
HI Simon,
Yes, trying to keep the work up.
I also have become more involved with Bidule as I actually BOUGHT it this January.
and keep digging things I never imagined before.
Hey, if you´re interested in some further exchange, check my profile and pm me
best
m.
last: PT11.3.1
Anyone know how to setup Plogue Bidule in PT8? hwalker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-28-2009 05:25 PM
Plogue bidule woodsdenis Pro Tools TDM Systems (Mac) 14 05-14-2009 07:17 PM
Plogue Bidule sleepingtiger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 07-18-2004 10:27 PM
plogue bidule output on 001 kmcou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-19-2004 07:21 AM
Plogue bidule - please help ! Simon666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-30-2004 11:40 PM
