HDX cards got (previous) firmware update, still nagging me.
So i am NOT yet running PT 2022.4 .... and yes i know HDX cards will need a special, NEW firmware update to run 2022.4 I am talking about the PREVIOUS HDX card firmware update.... I hadnt used these 2 HDX cards in a long while Using them with 2021.x Catalina Inside a Mac Pro 2019 (not a chassis) So clean OS install. Import user data via Mac OS.... all good. Ran ProTools just fine WITHOUT the HDX cards. All good. Cool... then did the usual Uninstall HD Driver, then re-install HD Driver. All good. then...when i first launched PT with HDX cards in the Mac Pro [HDX cards x 2] .... it said needed HDX cards firmware update I did both, watched it complete both. It was happy Shut down, the usual But now, every time i turn on it nags me "hdx card firmware update needed" right after boot up. Then runs fine and does not bug me I then PT trashed prefs Shut down Made new session, saved... all happy... Still nag after every startup. Also ran digi test (properly)... all good Any ideas why / how to remove the nag (only happens when rig first turned on) Thx |
Re: HDX cards got (previous) firmware update, still nagging me.
ps this is annoying.
Possibly do a NVRAM, PRAM, and SMC reset. Some of those query the hardware and they could not have re-queried since the firmware update so are reporting erroneous info to macOS on startup.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Curious if the suggested resets fixed this issue?
Also - where is the info about needing to upgrade the HDX card firmware in order to run 2022.4? I'm not seeing it in the 40-pages of release notes.
2019 Mac Pro 7,1 192 GB RAM Catalina OS 10.15.7 PT Ultimate, or whatever 2022.6 is called now HDX 2 w MTRX, Dadman 9.1.4 Dolby Atmos over Dante to external RMU |
update - i finally had time to do both a NVRAM (PRAM), and SMC reset.
nag still exists. will be running the rig hard today. will report back IF any isssues. |
can roll back to 2021.12 with the current firmware update done to the hdx cards | ejsongs | Pro Tools | 3 | 05-01-2022 05:47 PM |
Protools 11.1.1 wants to do a firmware update on HDX cards | Redbeard | Pro Tools HDX & HD Native Systems (Mac) | 9 | 01-13-2014 08:46 AM |
Firmware Update HELP. My 003 Rack will not update Firmware. | New003RackUser | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-17-2007 09:01 AM |
Does the latest cs update contain all the previous ones? | max cooper | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-07-2007 09:57 AM |
Firmware update for mixfarm/d24 cards? | Fucius | General Discussion | 0 | 04-23-2001 06:10 PM |
