Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 07-09-2021, 09:38 AM
Goombot Goombot is offline
Default 2 MTRX Studios with HDX2
So I got two MTRX Studios hooked up to my HDX cards and I don't seem to be getting any sound out of the 2nd MTRX Studio. Jeff went over this briefly but I might need a bit more detail to figure out what I'm doing wrong. I'm pretty sure it's Dante routing. This is what I have so far.
ProTools and DADMan are recognizing both cards.
Dante Controller sees both MTRX Studios and RedNetPCIeR card and all devices are subscribed and locked.
MTRX1 has Digilink Port1 connected to HDX1 port1
MTRX1 has Digilink Port2 connected to HDX1 port2
Dante Port1 out into Cisco switch
MTRX2 has Digilink Port1 connected to HDX2 port1
MTRX2 has Digilink Port2 connected to HDX2 port2
RedNet PCIeR card in Mac Pro hooked into switch from primary port.
All Digilink inputs routed to Dante outputs in DADMan for both cards
All Digilink outputs routed to Dante inputs in DADMan for both card.
So my issue is that I still am not getting any sound out of the second HDX card. Everything that is routed in my Atmos session to anything from ch. 65 on up I can't hear. If I switch back to Dolby Bridge I hear everything fine.
So, is there something specific I need to do routing wise with this 2 MTRX Studio setup? Is there something I am missing? Also, do the 2 MTRX's need to be linked together in some fashion? And finally, is there some setting in the DADMan synch that I need to change?
Old 07-09-2021, 11:54 AM
Default Re: 2 MTRX Studios with HDX2
Figured it out. Didn't set 128 channels in and out in the Audio Midi setup. So officially working 2 MTRX's.
Difference between MTRX and MTRX Studio? snowplaysmusic Pro Tools | MTRX & MTRX Studio 4 11-26-2022 08:48 AM
New rig issues- 2x MTRX Studios and an HDX TB3 adebarwick Pro Tools | MTRX & MTRX Studio 18 08-02-2021 09:19 AM
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
2 MTRX Studios Goombot Pro Tools | MTRX & MTRX Studio 8 07-07-2021 03:54 PM
MTRX Studio with HDX2 and Mac Pro 2019 Goombot Pro Tools | MTRX & MTRX Studio 5 06-25-2021 08:04 AM
