BPM problem when importing drums
Hi, a new issue that did gave me some headache. When I edited drums in cubase for a song I exported them and made them sd2 and then I laid all my tracks on them and finished the songs, but I wasn't happy with the drums, so I went back to cubase, did some editing and exported and imported the tracks agian into protools and replaced the old ones.
Now suddenly the drums were too fast. Exactly 1 bpm to fast. I quickly changed it and everything was cool, but how could it had happen, the BPM in cubase was exactly the same as before, nothing changed. Just, curius, could it be something with the fact that I had laid all the 16, or something, tracks and put plugins on them or just this one time with this one song. I tried the procedure several times. Any thoughts? Cheers Bascani |
Re: BPM problem when importing drums
I have had similar problems when bouncing to a DA38 and back.
I sent two tracks that I had bounced down from Pro Tools LE via 001 / Tascam IF-TAD interface to a DA38 (One track with click track, the other with the music, recorded drums on the remaining 6 tracks on the DA38, brought all 8 tracks back to the PT LE session via 001 / IF-TAD and found that the BPM had changed by .5 milliseconds. I don't know why or how this happened, but it's happened to me on two separate occasions. Always by around .5 milliseconds. Anybody have any ideas why this type of thing happens? |
Digi how about a reply on this one?
Not sure what is happening, but here are my initial thoughts:
-Check the sample rate of the session and make sure it hasn't changed...this will change the playback speed of your audio. -If you are resolving your system to an external source, swith PT LE back to "Internal" (Setups>Hardware window) and see if anything changes. Latency: -The H/W Buffer setting (Setups>Hardware window) may have something to do with this. If you are bouncing your audio before transferring it (as guitarrob) is doing, check the very beginning of the bounced file for any "dead space". Guitarrob, assuming you mean 5ms and not .5ms, I'd be curious to know if you were bouncing with a 256 sample buffer value. Brent |
Dae error when importing single wav (drums) | yisalltherumgone | Pro Tools M-Powered (Win) | 5 | 04-01-2009 06:17 PM |
Friend Having CPU Overload Problem and Importing problem | thegreatgrizzly | Pro Tools TDM Systems (Mac) | 2 | 12-16-2008 02:01 PM |
NewBie - Importing Drums Loops in PT ?? | GWeideman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-26-2004 02:09 PM |
Importing Midi Drums | steals | MIDI | 6 | 02-18-2002 12:13 AM |
Importing Naked Drums -- Help Bassmac | Jepse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-03-2002 04:54 PM |
