Old 10-11-2004, 02:04 PM
speedyk5 speedyk5 is offline
Default Fader pack failure!!Help Digi
Hi
After a short time of fuctioning fader pack freaks out!!.All the leds and faders fuctioning like crazy!!When you switch it off and power again it works for an hour and then the same problem again!Any ideas to fix this??
Old 11-05-2004, 09:16 AM
agus agus is offline
Default Re: Fader pack failure!!Help Digi
I'll bet you're having the same problem I had, although mine was with the main section. All of a sudden you see chineese characters scrolling across and it goes nuts. Then it resets and is fine for awhile? Well, the problem is probably in the power supply. Those capacitors dry up after a few years and once the system starts seeing funky power, all hell breaks loose. I luckily had another ProControl, so I swapped power supplies. Solved the problem. So now I'm recapping the old one, and I'm sure that will fix it. Not hard to do.
FS: Procontrol-Edit pack-Fader pack vudoo Buy & Sell 1 12-17-2013 01:48 PM
Procontrol with fader pack and edit pack The golfer Buy & Sell 2 11-05-2012 08:47 PM
HELP! Edit Pack thinks its a Fader Pack! digitaltoast ProControl, Control|24, Command|8 1 01-27-2012 03:48 AM
Is Procontrol/edit pack/ fader pack still supported vudoo Pro Tools 9 8 11-06-2010 08:19 PM
'Fader Pack' and ProControl Fader order issue Ciaran ProControl, Control|24, Command|8 2 03-21-2005 11:58 PM
