Old 09-04-2020, 04:56 AM
frenchman frenchman is offline
Default Import stereo file generates two mono tracks ?!?!
I am increasingly plagued by this very annoying problem :
When I import wav files exported from some other daw, Pro Tools often creates two mono tracks instead of a stereo one, anybody knows why ?
Thanks
Mark
Mark Haliday
France, Rochefort 17300
Mixing & Mastering, Writer, Teacher
Pro Tools Ultimate & Carbon
M2 Max Studio
Old 09-04-2020, 05:14 AM
danyg danyg is offline
Default Re: Import stereo file generates two mono tracks ?!?!
your session has to be "interleaved" when you create it
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 09-04-2020, 05:47 AM
Now, at any time, you can go into session setup & select interleaved .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 09-04-2020, 06:50 AM
Well this is the first thing I did and it didn't do any good. 5' later, importing from logic worked perfectly. Maybe the way the other Daw (Cubase) formatted the Interleaved files
Envoyé de mon SM-G950F en utilisant Tapatalk
Mark Haliday
M2 Max Studio
Old 09-04-2020, 07:07 AM
So am I understanding this;
Stereo interleaved file from Logic comes in as interleaved .
Stereo interleaved file from Cubase comes in as dual mono ?
Strange . .
Old 09-04-2020, 07:11 AM
if you created an interleaved session and the other person exported them as 2x mono they will also be mono in your session. So it's not your fault.
Old 09-04-2020, 07:15 AM
True. . .
So make a stereo track & pop the dual mono's onto it . .
Old 09-04-2020, 07:49 AM
Strange . .
No they are legit interleaved files but ProTools wants to split them on two mono tracks for some unknown reason...
Mark Haliday
M2 Max Studio
Old 09-04-2020, 07:52 AM
How are you importing ?
Drag n drop, or shift command I ?
Old 09-04-2020, 07:53 AM
Shift Command I
I am going to investigate this further but I am recording presently so I will have to wait a few days
Mark Haliday
M2 Max Studio
AAF import from Logic Pro X - how to combine mono L-R tracks to stereo steins Post - Surround - Video 1 01-20-2017 05:27 PM
separating 2 mono tracks from a stereo file nibtgom Pro Tools 10 4 10-13-2016 06:17 AM
Audio import on stereo tracks instead of dual mono ? vudoo Pro Tools 11 9 06-14-2016 03:25 AM
HOW can you import a "stereo" WAV. file into PT as a "mono" file? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2002 09:14 PM
What do i import a "dual mono" audio file as??? mono or split stereo? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-17-2002 04:02 AM
