Old 03-14-2022, 10:17 AM
ReynaldoPena ReynaldoPena is offline
Default Gain Plug In | DSP Enabled
Hey APA,
Good afternoon. How are you? Hope all is well. I am looking for a gain that will allow me to record with the Pro Tools Carbon. Any help would be greatly appreciated. Thanks
Take care brush your hair,
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
iMac (Retina 5K. 27-Inch, 2020)
Processor 3.6 GHz 10-Core Intel Core i9
3.6 GHz Dual-Intel Core i7
16GB ram
AMD Radeon Pro 5700 8GB
Shure SM7B Mic
Pro Tools | Carbon
Komplete Kontrol M32
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 03-14-2022, 10:51 AM
BScout BScout is offline
Default Re: Gain Plug In | DSP Enabled
The given "Trim" plugin also gains and is DSP
Old 03-14-2022, 12:22 PM
I have to ask......why? In 18 years of recording in Pro Tools, this has never been something I needed or have ever seen anyone use
Old 03-14-2022, 01:07 PM
Top Jimmy's Avatar
Is he possibly referring to a preamp?
James Cadwallader
Old 03-14-2022, 01:36 PM
Tough to say what the question is(especially as Carbon has preamps)
Old 03-14-2022, 01:39 PM
Top Jimmy's Avatar
Been a long time since I’ve been on TDM/HD. Was/Is there a DSP version of the trim plugin?
James Cadwallader
Old 03-14-2022, 04:00 PM
Yes. Always (and currently)
Old 03-14-2022, 06:36 PM
Carl Lie Carl Lie is offline
You could try the Sonnox Oxford Inflator or a compressor with make-up gain or just use clip gain.
Hard to know what to reply given not sure what your trying to do.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 03-16-2022, 06:34 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Apologies for being 'that guy' but I've used Gain on inserts a good number of times.
Here's a couple of situations. Stereo track with multiple playlists for editing?
One channel is a bit hot (or cold). Add dual mono Trim plugin and adjust one side by a dB or two. One side needs phase flipping? Gain insert does the job.
Where there are multiple playlists it saves hassle being on an insert, at least until you have comped everything.
Another situation I have used Gain to add level or attenuate into the next plugin in the chain when it doesn't have the facility to trim the input.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 03-16-2022, 08:43 AM
daeron80 daeron80 is offline
That's one I often use. Especially with certain SoundToys plugs. Devil-Loc sounds great on some things, but it can boost level by dozens of dB, and even the deluxe version has no output trim. Drives me crazy.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Error: Plug-ins not enabled- not 64bit compatible js_nyc Pro Tools 12 5 11-19-2019 01:22 PM
Clip gain o Gain plug in Camilo Toledo Foro en Español 3 03-22-2017 02:10 PM
copying auto-enabled EQIII plug-in causes hang jimlongo Pro Tools TDM Systems (Mac) 0 11-23-2005 10:03 AM
RTAS plug on record enabled track... JR Fountain Pro Tools TDM Systems (Mac) 13 10-03-2005 07:33 PM
RTAS plug-ins on record enabled audio tracks?? modul8tr Pro Tools TDM Systems (Mac) 6 06-26-2002 08:02 AM
