Saving session while it plays
So is this a no no? When I hit Cmd+S while the session is playing it halks playback and produces white noise. I thought you should be able to do this but maybe I'm wrong.
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core 16 GB RAM Mountain Lion 10.8.5/El Capitan 10.11 Focusrite Saffire Pro 40 Ableton Live 10/Presonus Studio 3 |
Re: Saving session while it plays
I do it all the time. Never have any problems. It's probably not the best idea to ask your computer to take on another operation like saving files when its already loading/playing files, but I don't seem to have problems.
I'm guessing that an operation like this would require a good deal of processing power. It's all subjective and will probably have lots to do with what kind of session you are running, with what level of processing power is required, then on top of that, can your computer handle doing that.
www.TheSoundCoop.com www.youtube.com/TheSoundCoop PCAudioLabs 2.5GHz Quad-Core Q8300 FSB:1333/1066MHz, NB:IntelG33, SB:Intel ICH9DH/WinXP Pro SP3 / SATA HD's = 160GB(7200/8), 320GB (7200/16) x 2,500GB (7200/32) / 4GB DDR2-800 / FW = TI ChipSet / Gear: Apogee Rosetta800, ADL600, Avalon2022 // M-Audio = Profire Lightbridge, Octane 8's, BX5's BX8's & SBX // ProTools MP 8.0.5 w/ MPTK 2 - Velvet Waves Sonnox IK NI FXpansion Massy -- DVerb2.0 Test = 230 verbs |
24-bit 44.1 session. Hardware set at 256 recording/playing from dedicated 250GB 7200speed drive. Cpu was about 17%.
I don't seen any reason why any of that should me giving it a problem.
Does this happen with every session or just the one you are working on right now. Does it not happen on sessions with less tracks or audio regions? Are you going nutz with plugins? If so set your buffer to max. 1024 or higher. I always do this when I'm mixing something. I try to keep away from serious plugin use when tracking. If you make a new session with just one audio track and its audio region, do you still have a problem? Have you cleaned up your HardDrive lately? Moved the audio to an external and then back? Maybe the reason why I don't have problems is cause I have a quad core. I'm sure that my ProTools can run pretty well on 2 cores. So that leaves one dedicated for OS use and another one for random processing not related to PT. Since you have a Dual core, try lowering the processors used inside ProTools to 1. See if it still give your problems. My friends that run Dual Core machines seem to have lots more problem then I ever do. Maybe it just comes down to processing power.
I used to do this on a G5 single processor rig all the time. It shouldn't be a problem. I would definitely try this on another session and see if you have the same results. Try cleaning up the drive, try trashing preferences, databases, all the usual stuff. Repair Permissions etc, I would just start going down the list so to speak because on every rig I've used, I have been able to save during playback. I only know this because i am a bit obsessive when it comes to hitting save during sessions. Good luck, and let us know how it turns out!
Mac Pro Quad-core 2.6, 5 gig ocz ram,1Tb hd internal, OSX 10.5.7, 2 internal Audio HD,lacie 500 gig external fw 800 drive Digi 003 rack, PT le 9.0.1, Mac Book Pro 2.4ghz I5, 4 gig ram, PT 9.0.2, Apogee duet Waves gold, and ssl plugins /Reason4 /miroslav philharmonik /stylus rmx /Melodyne /T-racks3 deluxe / Strike /Massey compressor, DTM /Sound Toys /blah blah etc. UA610 pre's / Chameleon Labs 7602mkII pre's / Chameleon labs 7802 stereo opto tube compressor/ Mackie hr824 monitors |
48k Session only plays correctly with 44.1 clock? | JB3 | Pro Tools TDM Systems (Mac) | 3 | 10-19-2013 05:16 PM |
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 | doubtful guest | Pro Tools TDM Systems (Mac) | 1 | 02-06-2013 03:42 AM |
Saving a session while it plays | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-09-2009 01:16 PM |
Help...session plays from the wrong spot? | IndreStudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-01-2007 01:30 AM |
? saving session as/saving copy of session in | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-05-2002 10:24 AM |
