Old 01-22-2015, 10:18 AM
AMIEL AMIEL is offline
Default Is there is a way to have Pro Tools Mixer/Editing Window to Follow the selected fader
The same way when u select a track in Pro Tools windows and Artist Control (MC Control) follows the track can be the other way arround?
to have Pro Tools Mixer/Editing Window to follow the selected track in MC Control??
Thanks!
Reuven Amiel
Mixer/Producer.
Old 01-22-2015, 10:34 AM
mesaone mesaone is offline
Default Re: Is there is a way to have Pro Tools Mixer/Editing Window to Follow the selected f
It's a feature that is supposed to work, but has been broken for years.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 01-22-2015, 12:21 PM
That feature is a MUST, breaks all the workflow that Artist series can give
is there any way around??
Thanks!
Reuven Amiel
Mixer/Producer.
Old 01-22-2015, 12:40 PM
For me, the thing that works is a Pro Tools shortcut that scrolls a selected track into view. If I hold the START button on my keyboard while using one of the MC Mix select buttons, it works.
I believe the Mac modifier is Shift+Control.
Old 01-22-2015, 02:54 PM
Thanks for your reply.
No idea what is th START Button but I guess u modified that buttom to be Shift+Control. and by holding the MC Mix select buttons....takes u to the track?? did I understand correctly?
Thanks!
Reuven Amiel
Mixer/Producer.
Old 01-22-2015, 03:03 PM
The Start button is a Windows modifier key. Holding the Start key and clicking on a track will scroll it into view. It turns out that this works when holding the Start key while pressing the Select button for a track on the MC Mix control surface.
If you are using mac, the modifier will be different because there is no Start key on Mac. I can't be sure, but I believe you can hold control+shift and press the Select button on the control surface.
Old 01-23-2015, 12:06 AM
Thanks!! great tip
Thanks!
Reuven Amiel
Mixer/Producer.
Old 03-03-2015, 02:28 AM
edwinstar's Avatar
edwinstar edwinstar is offline
On my Mac it works when i press the "ctrl" Key on the Keyboard and on the Artist Mix controller press the Assign/Sel Button of the channel that needs to come into view.
Old 03-06-2015, 01:46 PM
priorytools priorytools is offline
Wow .
Well discovered edwin .
I wonder if that'll work on the S6 ?
I shall try it on Monday.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 03-09-2015, 07:56 AM
Yes, that works on S6 .
It also works using the ctrl on the S6 fader modules.
Pro Tools 8 Problem All tracks are selected for everything in edit window. DONNX Pro Tools TDM Systems (Mac) 16 08-30-2021 04:31 AM
Mixer fader in edit window like logic. Possible? imz14u Pro Tools M-Powered (Mac) 3 09-09-2015 11:48 AM
Can mixer be set to follow edit window selections? Protone macOS 2 09-11-2013 05:04 AM
how do i make windows follow selected track? fork-media Post - Surround - Video 4 08-14-2013 04:57 AM
MC Control follow selected track? thebeatless Artist Series 0 03-07-2011 10:14 PM
