Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 06-14-2006, 05:47 PM
imz14u imz14u is offline
Default Mixer fader in edit window like logic. Possible?
Is it possible to have a tracks mixer fader to be in the edit window like Logic does? I would like to have an all "in one window" edit window so i don't have to keep jumping between the mixer and edit windows.
Old 06-14-2006, 08:34 PM
Default Re: Mixer fader in edit window like logic. Possible?
thanks man. was looking for something a bit different though. in logic if you click on the track the entire channel strip shows up on the left hand side of the arrange window. including the inserts and bus's. your way works but was not exactly what i would have hoped pt would do. if anyone else knows please post!
Old 06-18-2006, 08:54 AM
ScratchDee ScratchDee is offline
View menu -> edit window -> I/O (or ALL)
then click on the mini-fader symbol under the green vol & pan display.
this will open a "standalone" fader of this track incl. I/O, pan, mute, solo...
forget about logic when working with PT
Old 09-09-2015, 11:48 AM
Patso Patso is offline
Hold Ctrl while you click on the green numbers underneath the I/O - it will bring up a little fader where that you can adjust without having to pull up a fader window. (More like what Logic has set up)
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
Can mixer be set to follow edit window selections? Protone macOS 2 09-11-2013 05:04 AM
Changing Edit Window Colors To Look More Like Logic 8? (PT8 Skinnable?). epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-30-2009 06:35 AM
Fine adjust fader in edit window caput! command+adjust crizdee Pro Tools TDM Systems (Mac) 2 12-09-2008 03:55 PM
Track Level Fader in edit window Maud 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-19-2006 09:34 AM
