Mac - Spotlight cannot find ptx files when they are resaved
I use Smart Folders (saved searches) in macOS to easily find and load Pro Tools sessions.
This has worked well, but I recently found a problem: 1. Create a new Pro Tools session - the new ptx session file automatically appears in the saved search folder. 2. Resave the session with File/Save - the ptx session file in the saved search folder disappears. 3. File/Save As and overwrite the session with the same name - the ptx session file in the saved search folder reappears. The same things happens when I directly search for the ptx file with Spotlight. Spotlight cannot find the ptx file when it is resaved with File/Save. I didn't used Pro Tools for a few months, so I’m not sure whether a certain PT update or macOS update caused this problem. I haven't found another application that shows this problem. Can anyone confirm the problem? Thanks for your help. A Guide to Using Smart Folders on MacOS https://theproductiveengineer.net/a-...ders-on-macos/
Pro Tools 2023.9 Ventura 13.6 |
Re: Mac - Spotlight cannot find ptx files when they are resaved
I'm definitely no expert, but I have used a bit of smart folders and folder scripts over the years. Could it be a finder/spotlight problem? That mds process not updating? A simple save in PT is in essence replacing the session file with a new session file.
Does it show up after a while, after a restart? A restart of the Finder, perhaps? Might there be a way to "force" a update of the mac "file awareness"? |
It doesn't show up after Mac or Finder restarts. Some new things I've tried. 1. Close and restart Pro Tools and then open the file from the Open/Recent menu - It does not reappear. 2. Close and restart Pro Tools and then open the file by double clicking on the real ptx file in the PT Sessions folder - It reappears. Quote:
It looks like it's a Spotlight problem on my computer. Strange it only affects Pro Tools. I've got a spare SSD, so I'll try doing a fresh test installation of Mojave to see if there's still a problem.
Pro Tools 2023.9 Ventura 13.6 Last edited by Richard901; 06-15-2020 at 03:10 AM. |
Different SSD - reformatted. Fresh installation of Catalina 10.15.5 - I was using Mojave. Only system SSD attached. No other third party software installed. Pro Tools 2020.3 New session. Same problem - the session ptx file in the Saved Search folder disappears when the project is resaved.
Missing fade files, missing audio in resaved sesssions | drygruo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-14-2010 04:56 PM |
Spotlight can find PT Documentation, but PT itself can't? | The Dubnicks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-16-2009 04:53 AM |
Spotlight and Find command disabled by Protools? | Zownd | Pro Tools TDM Systems (Mac) | 2 | 06-05-2008 07:59 AM |
Spotlight and "Find" suddenly not working? | JKD99 | Pro Tools TDM Systems (Mac) | 2 | 02-11-2006 12:48 PM |
*HELP* LE 6.2 can't find any of my files! | Brandon Burke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-29-2004 11:35 AM |
